Better way to "IPR Selected Only" Feature Request
Forums: Better way to "IPR Selected Only" Feature Request
Postby 3dreamstudios » Tue Jul 25, 2017 3:01 pm
3dreamstudios Tue Jul 25, 2017 3:01 pm
So I have some pretty big scenes (for me) that sometimes take 20-60 seconds to load up. When I get this big I still like to pop in and tweak textures as they relate to other things in the scene.
Currently the only way to do Sel Only IPR is to load IPR and quickly press Sel Only, if it wasn't already checked. This is a bit wierd, as I would typically want to select an object and then open IPR with Selected Only already checked.
It would be very nice to have a button for IPR Sel Only on the menu and a regular IPR Full or whatever. Maybe this can happen in the future...with script currently? Thanks for any thoughts.
3dreamstudios
Re: Better way to "IPR Selected Only" Feature Request
Postby 3dworks » Wed Jul 26, 2017 10:33 am
3dworks Wed Jul 26, 2017 10:33 am
+1
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
3dworks
Postby juanjgon » Thu Jul 27, 2017 4:13 pm
juanjgon Thu Jul 27, 2017 4:13 pm
I can add a new command that you could add to the menu or map to a key to open the IPR in the selected only mode. Should be easy ;)
juanjgon
Postby 3dreamstudios » Thu Jul 27, 2017 4:21 pm
3dreamstudios Thu Jul 27, 2017 4:21 pm
juanjgon wrote:I can add a new command that you could add to the menu or map to a key to open the IPR in the selected only mode. Should be easy ;)
That would be great. Just a small tweak to work flow! Thanks.
3dreamstudios
Postby juanjgon » Sat Mar 03, 2018 8:49 pm
juanjgon Sat Mar 03, 2018 8:49 pm
In the next plugin build there are going to be two new commands to open the IPR with the "selected only" option always enabled or disabled.
juanjgon
Postby BorderLine » Sun Mar 04, 2018 5:03 pm
BorderLine Sun Mar 04, 2018 5:03 pm
Perfect ! Waiting !
BorderLine
Postby 3dreamstudios » Mon Mar 05, 2018 1:34 pm
3dreamstudios Mon Mar 05, 2018 1:34 pm
Thanks! This will be a welcome feature.
3dreamstudios
Postby 3dreamstudios » Tue Mar 06, 2018 2:02 pm
3dreamstudios Tue Mar 06, 2018 2:02 pm
juanjgon wrote:Hi,
Juanjo,
Did this make the RC build update for 2018? I'm not seeing it anywhere. Also, unless I'm reading this wrong, it would be a much better solution for my needs to have as originally described above, a command that could be mapped to open IPR with selected or IPR full. As having a default option is probably a nice thing, it doesn't get away from the long load issue I have when I'm wanting to go from one to the other. If I was using selected before...and now I want to load the entire scene or vice versa I must wait for the scene to load and then uncheck/check SEL only.
Thanks for the update to 2018, it's been a long time coming...and I know it's been bad for you too, since you had no control but had to endure the frustration, from me and others! :)
3dreamstudios
Postby juanjgon » Tue Mar 06, 2018 2:55 pm
juanjgon Tue Mar 06, 2018 2:55 pm
Have you added the plugin again to your LightWave? You must remove the old plugin and add the new one to get the new commands (remember to remove the master plugin before updating it).
This is how it works, you have two commands that you can map to a key or add to the menu branch ... one will open the IPR in selected objects mode only and the another one will open the IPR in full scene mode, without switching the mode in the IPR window.
juanjgon
Postby 3dreamstudios » Tue Mar 06, 2018 3:01 pm
3dreamstudios Tue Mar 06, 2018 3:01 pm
juanjgon wrote:Have you added the plugin again to your LightWave? You must remove the old plugin and add the new one to get the new commands (remember to remove the master plugin before updating it).
Yea I installed in 2018 fresh. How you describe it would be perfect. I did see the command under the additional/utilities but initially it did not do anything.
Let me try again with a restart or something. Sounds like it should work as expected. Thanks for the reply.
3dreamstudios
Next
Return to Lightwave 3D
Users browsing this forum: No registered users and 28 guests
Thu Apr 25, 2024 12:25 am [ UTC ]
