juanjgon wrote:AndyM1969 wrote:Massive problem with this release, Octane volumetrics is causing a crash every time on new and existing scenes.
Can you please provide more details about this problem? Here all my volumetrics unit tests work fine.
Could be useful to know what kind of volumetrics you have this problem (TFD, VDB, etc.), the LightWave, NVIDIA drivers and OS versions, your system specs, etc. If you can enable the log file in the plugin options panel and attach it here, we could know more details about the crash point. A sample scene with this problem could also help.
AndyM1969 wrote:Nope, every time I load an existing scene with Octane volumetrics the scene crashes when I go to edit the volumetrics. I've just given up and gone back to an earlier version. One day this plugin will be worth the money I've spent on it.
juanjgon wrote:Sorry, I'll take a short break for vacation, so probably there is not going to be a new Lightwave or Houdini plugin builds until September. I'll check also the reported bug about instancing for the next build, although anyway the instancers on/off feature only works for the first one due to a limitation in the LightWave SDK. The crash can be related to this limitation, but I'll try to fix it.
Thanks for your patience,
Users browsing this forum: No registered users and 24 guests
