Smooth problem with glossy
Posted:
Mon Feb 28, 2011 12:46 pm
by scratch33
I post here because I think it's a lightwave export problem.
Here is what I got if I try to render a glossy material.
smooth is on.
Can you help me please? Thank you.
Re: Smooth problem with glossy
Posted:
Mon Feb 28, 2011 6:49 pm
by scratch33
I think that this is the plugin that don't work properly.
I have exported the object from modeler without the plugin and textured in octane and I don't have this issue.
But I want to do animation and I must use the plugin...
Is there anyone who could confirm the bug?
- Do a sphere in modeler with enough polygons.apply a material with smooth active.
- export in layout.
- from layout export in octane with the plugin.
- apply a glossy material on the sphere.
- apply a hdri map in environment.
- zoom...
Thank you very much.
Posted:
Tue Aug 23, 2011 12:59 pm
by marchermitte
I suffer the same problem and didn't find a fix yet. I tried to export the obj fromn Modo and replace the Lw export ,then re-open the Octane scene, no sucess... still facetted. (Very simple polygonal mesh, no dub-d used.)
Anyone has got a tip? (other than give up lightwave, please)
Posted:
Tue Aug 23, 2011 2:20 pm
by scratch33
Salut,
Here is a tip. Works well but a bit tricky. And usefull only with animation without deformation...
third message :
viewtopic.php?f=24&t=6894The point is to export from modeler the good version with internal exporter, then export from layout with plugin.
Hope this bug will fixed soon...
