export materials from LW
Forums: export materials from LW
Postby roger1972 » Sun Oct 10, 2010 6:44 pm
roger1972 Sun Oct 10, 2010 6:44 pm
Hi!
when i export a scene to octane using your plugin, I can only export diffuse material with UV-texture.
is there some way i could export bumpmaps change materals etc.
i7 3770 / 16GB / GTX 780 6GB
roger1972
Re: export materials from LW
Postby holocube » Mon Oct 11, 2010 3:11 pm
holocube Mon Oct 11, 2010 3:11 pm
You should just be able to assign to bump channel in surface as usual.
If you open the created .mtl after exporting it should have an entry for map_bump
GTX260 Seven 64bit
I'm Superfrog
holocube
Return to Lightwave 3D
Sun May 31, 2020 2:22 pm [ UTC ]
