Smoothing Angle requires reload IPR
Forums: Smoothing Angle requires reload IPR
Postby MrFurious » Thu Jan 16, 2014 11:23 am
MrFurious Thu Jan 16, 2014 11:23 am
Just a quick one.. I noticed that changing the smoothing angle for any given surface requires one to reload IPR to see the changes. Is this a bug or a necessary evil. Can be quite time consuming for larger scenes.
Cheers,
Dino.
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
MrFurious
Re: Smoothing Angle requires reload IPR
Postby juanjgon » Thu Jan 16, 2014 11:21 pm
juanjgon Thu Jan 16, 2014 11:21 pm
Reversion1970 wrote:Just a quick one.. I noticed that changing the smoothing angle for any given surface requires one to reload IPR to see the changes. Is this a bug or a necessary evil. Can be quite time consuming for larger scenes.
Cheers,
Dino.
Yes, this is known issue. Problem is that smoothed normals are not available in Lightwave until you change the smoothing angle parameter. So after change this parameter, Octane needs to reload the scene again to get the new smoothed normals from the Lightwave scene. Currently I don't know a way to fix it.
juanjgon
Postby MrFurious » Sat Jan 18, 2014 11:55 pm
MrFurious Sat Jan 18, 2014 11:55 pm
Thanks Juanjo, whilst not a huge issue it would be a significant timesaver in some scenes. My workaround for now is to set smothing values in modeller, leaving less tweaking in layout. Do you see a potential fix in future versions of the plugin/lightwave/sdk?
Cheers,
Dino.
Dino Inglese
CG Artist
Melbourne Australia
MrFurious
Postby juanjgon » Sun Jan 19, 2014 10:18 am
juanjgon Sun Jan 19, 2014 10:18 am
This issue is not going to be easy to fix. Perhaps you should adjust the smoothing angle of the surfaces in a simple scene with only this object to make the reload process faster.
juanjgon
Return to Lightwave 3D
Users browsing this forum: Bing [Bot] and 4 guests
Fri Feb 28, 2020 10:44 pm [ UTC ]
