Sequence time remaining
Forums: Sequence time remaining
Postby fibernaut » Fri Nov 08, 2013 7:32 am
fibernaut Fri Nov 08, 2013 7:32 am
Hi Juan
I wonder if it's possible to integrate the estimated time for finishing the rendering of an animation. Now these informations are only per frame. It would be nice to quickly see how long the rendering will take approximately.
Just to know if i have to stay awake for another hour waiting for completion or if i can finally go to bed. :)
Win 10 64 | 3x GTX1080Ti 2x Xeon E5 2650v2 | Supermicro X9DAi | 128 GB ECC Reg.
Win 10 64 |2x GTX980Ti | i7 9700K | Gigabyte z390 Aorus Master | 64 GB
Win 10 64 | 2x RTX2070 2x RTX2070super | I7 2600 K | 32 GB
fibernaut
Re: Sequence time remaining
Postby glimpse » Fri Nov 08, 2013 7:46 am
glimpse Fri Nov 08, 2013 7:46 am
I believe it should be difficult to evaluate time needed, 'cos camera angles, material or even light might change from frame to frame, and that might 'cause required time variations.. - best idea is probably to render out sequence with low def presets, anyway You probably need to check out for any unplanned issues & then simply calculate how much time You need overall depending on how much You raised the quality for final output =)
tomGlimps | [email protected] | 32GB | TitanBlack
Available for Freelance, Coaching & Mentoring
glimpse
Return to Lightwave 3D
Sun Feb 23, 2020 1:59 am [ UTC ]
