Page 2 of 7
Re: Lightwave 3D Plugin v0.3
Posted:
Tue Aug 24, 2010 7:37 am
by scratch33
I don't know if it's me, the plugin, or octane...
But when I export an object and I set the images to be used in lightwave, octane load the object without the images.
I must resetup all in octane.
I have switched ON all the options in the octane import preference but he don't works.
Any idea?
Thank you.
Posted:
Tue Aug 24, 2010 10:08 am
by holocube
Something is funky with the material file .mtl perhaps. Does this happen with every object?
Posted:
Tue Aug 24, 2010 10:14 am
by scratch33
Yes, all objects.
It happens also with "Export Obj/MTL only" button.
Posted:
Tue Aug 24, 2010 10:52 am
by holocube
could you share a written obj mtl and the texture. just a cube is fine
Posted:
Wed Aug 25, 2010 6:41 pm
by salvation
hi
can you add a stop-button?
because if the render is bad i must kill lightwave to stop the render
Posted:
Thu Aug 26, 2010 9:29 am
by holocube
Bug in lscript, not possible to use the progress thing in layout.
NT knows about it.
Posted:
Sat Aug 28, 2010 4:53 pm
by roger1972
First of all, THANK YOU!!!!!
this made my life easyer with octane..
When it comes to materials?
I can export UV's all my surfaces is diffuse with UV'channel.
Iis it possible to autogenerate UV's on Octane Export? (or does it do that?)
Posted:
Sun Aug 29, 2010 6:26 am
by geo_n
roger1972 wrote:First of all, THANK YOU!!!!!
That would be a lightwave task. The simplest way is to atlas map all your materials with textures that have no uvmap, also bake all your procedurals after atlas map.I dont know if there`s a plugin that can do that in lightwave automatically since someone at newtek is asking for it recently.
Posted:
Sun Aug 29, 2010 8:32 am
by roger1972
In modeler you autobake all textures when you export OBJ's
Posted:
Sun Aug 29, 2010 1:05 pm
by geo_n
Even surface with no uvmaps? or procedurals? projection mapping exported as well?
