Lightwave 3D Plugin v0.3
Forums: Lightwave 3D Plugin v0.3
Re: Lightwave 3D Plugin v0.3
Postby funk » Tue Feb 08, 2011 10:46 am
funk Tue Feb 08, 2011 10:46 am
Just reporting a small bug. When you use export obj/mtl only, the obj file doesnt point to the correct MTL file, so importing into octane only has 1 surface.
The MTL is created correctly, its just that the obj file points to an mtl with the wrong file name. It uses the project name instead of the file name you type in when saving the obj
Win10 Pro 64 / Core i7-975 3.33GHz / 12GB RAM / GTX 1080 Ti + GTX 670 / 2x1920x1200 / MODO 13
funk
Postby funk » Sat Feb 12, 2011 12:14 am
funk Sat Feb 12, 2011 12:14 am
Here is a sample scene for the flipped polygon problem:
Create a box and send it to layout.
Save the scene, then export to octane using
- Octane Obj Export (win only)
- Obj properties: Fast
- write UV and Write point normal ON
You can then load the OBJ file back into modeler and see that its flipped.
I have attached a box scene, along with the files exported from the plugin so you can load into modeler and see the flipped box
OctaneRenderTest.rar
(6.89 KiB) Downloaded 122 times
funk
Postby marchermitte » Wed Aug 31, 2011 9:54 pm
marchermitte Wed Aug 31, 2011 9:54 pm
What about glossy surfaces not smooting at all? Is It going to be fixed anytime soon?
Or should I use Modo instead then Lightwave?
Thank you!
Marc Hermitte
Intel I7 4.5 Ghz, 24 gig ram, 2x Nvidia GTX 480, win 764bits
marchermitte
Previous
Return to Lightwave 3D
Tue Feb 18, 2020 1:45 am [ UTC ]
