Page 5 of 7
Re: OctaneRender™ 3.0 for LightWave™ - Alpha build 3.00.0.0
Posted:
Fri Dec 18, 2015 12:21 pm
by FrankPooleFloating
Apparently, meshes do not need to be closed... I just made a copy of dragon with gaping hole.. still works.
Posted:
Fri Dec 18, 2015 12:23 pm
by juanjgon
FrankPooleFloating wrote:...but you can't add volumetrics to any mesh, even the dragon if you bring it back in... From what I can tell, it can only be pasted onto mesh...
As soon as you link any texture into the absorption, scattering or emission inputs in the node editor, you should be able to select the mesh shape. Without any texture linked to these inputs, the plugin only has enabled the OpenVDB functions.
Posted:
Fri Dec 18, 2015 12:24 pm
by juanjgon
FrankPooleFloating wrote:Apparently, meshes do not need to be closed... I just made a copy of dragon with gaping hole.. still works.
It can work, or not
... the behavior of open meshes is unknown.
Posted:
Fri Dec 18, 2015 12:53 pm
juanjgon wrote:FrankPooleFloating wrote:...but you can't add volumetrics to any mesh, even the dragon if you bring it back in... From what I can tell, it can only be pasted onto mesh...
Aaaaaaahhhhhhhh. Roger dat.
Edit: The Memory (Use/Free): seems to be broken in F9. Showing 0/2630 on current render.
Posted:
Fri Dec 18, 2015 11:38 pm
by Bitboy
I did some more displacement tests with my models I've used it on and attached are IPR shots with displacement node settings and the displacement map itself. I felt it was better to have the different settings visualised as a result than just explaining it. Sorry if it seems excessive.
From what I've learned only the displacement amount will affect the displacement. The Shift value does absolutely nothing. When I set the displacement to 1 um it looks normal with no displacement. Any negative value pops it a specific amount back. Different negative values will not change it.
Posted:
Sat Dec 19, 2015 12:34 am
by juanjgon
The shift value is useless currently, it is deprecated. The next build will add the new mid-level parameter to control the displacement offset.
Posted:
Sat Dec 19, 2015 12:46 am
by Bitboy
Thanks Juanjo. Looking forward to testing it.
Posted:
Sat Dec 19, 2015 6:58 pm
by mdharrington
Bitboy wrote:juanjgon wrote:Do you have your drivers updated?-Juanjo
Running NVidia driver version 358.50 as it's the best one right now for Windows 10 as far as I can tell. Newer ones crashes the display driver.
If you have a 'select' 680 that falls under the WDDM 1.3 you will only be able to mix those 2 cards on windows 10 with 358.5.......don't try updating (yet)
http://nvidia.custhelp.com/app/answers/ ... phics-cardI am running 2x470's and a 970 and had to find this out the hard way.....windows 10 wont work with any other drivers with WDDM 1.3 and WDDM 2.0 cards in combination other than driver 358.50 (so far)
They are said to be releasing a driver fix in the future for this, but until then 358.50 is the only one that can mix older and newer cards (4,5, and some 6's)
Posted:
Sat Dec 19, 2015 7:57 pm
by Bitboy
I know about the WDDM issue and that's why I replaced my Quadro 4000 which was running with the Fermi GPU to the GTX 980. That solved the issue since my GTX 680 is also running with WDDM 2.0. I was p*ssed to say it mildly when I found out that my Quadro and GTX wouldn't work together - AFTER having upgraded to Windows 10. NVidia's track record with drivers have been taking a dive lately. Lots of problems for people with mobile versions and those with more than one graphicscard. That's why I'm running 358.50 since that is for me the most stable version. It's also the one several users recommended to run on the NVidia forums.
EDIT: Also the 358.50 driver will stop working with more than one graphicscard (only if you're mixing WDDM 1.3 and 2.0) if you run the latest Windows 10 upgrade (I'm on the fast insider release track). Found out when one card simply vanished after a Windows update to a newer build.
Posted:
Sat Dec 19, 2015 9:41 pm
by 3dcgmodeler
Ok got 3.o BETA going
cool works fast
The vdb files ok... how do I do and more info please
Mike
