- Implemented Octane Quad Lights, Spherical Lights and Volumetric Spotlights (via the Octane Light property on the Modo Area, Point and Spot Lights). Volumetric Spotlight "Light Medium", "Emitter Material", and "Barn Doors Material" can be set by dragging the Spotlight item onto the schematric and adding those channels to the Spotlight node.
I have resolved this in the next release. I can send you a test version. Are you on Octane Enterprise or Studio please?3DRelic wrote:Nope sorry, still had the same results. Thanks for looking though.
I suggest updating to the latest version of the plugin at https://render.otoy.com/forum/viewtopic.php?f=34&t=73539.haniya21e wrote:This is happening to me too. I'm using version 2020.1.0.161
I have an animation set up with daylight system and when I render the animation, frame 1 and 2 doesn't connect as if the sun flies off to a wrong position.
It renders correctly when I render individual frames, but I would prefer to not manually render every frame when I can press "Animate".
Will this be fixed on the next release?
Users browsing this forum: No registered users and 18 guests
