Importing Realflow
Forums: Importing Realflow
Importing Realflow
Postby wolvy » Sun Jul 05, 2020 11:17 pm
wolvy Sun Jul 05, 2020 11:17 pm
Hello, I am trying to render an animation in Modo 14 with Octane 4.05 Win10, 2x Titan RTX.
I can not get the .bin and .obj mesh to re-import for each frame using the emReader. This did work in Modo 8 with Octane 3.0 Since then the tick for re-import meshes global has changed.
I have also tried a stitched .abc file and can not it to render at all in the Modo plugin.
Thank you for your time!
wolvy
Re: Importing Realflow
Postby Hesekiel2517 » Mon Jul 06, 2020 7:31 am
Hesekiel2517 Mon Jul 06, 2020 7:31 am
I don't know if that helps, but you can work around this problem by using proxys.
So open your alembic file in Octane Standalone and set up your materials there, then save as orbx.
Create a new mesh and load the orbx as a proxy.
By doing this you are bypassing modo and i think this works great.
Hesekiel2517
Return to Foundry Modo
Who is online
Users browsing this forum: No registered users and 3 guests
Sun Sep 27, 2020 6:23 pm [ UTC ]
