OctaneRender 2020 for Modo [OBSOLETE]
Forums: OctaneRender 2020 for Modo [OBSOLETE]
Re: OctaneRender 2020 for Modo [TEST and STABLE]
Postby SreckoM » Thu May 06, 2021 4:17 pm
SreckoM Thu May 06, 2021 4:17 pm
face_off wrote:I have now added Linux installers for the plugin at the top of this thread.
Thanks Paul, you are the best!
SreckoM
Postby jwfvr » Thu May 06, 2021 8:20 pm
jwfvr Thu May 06, 2021 8:20 pm
it seems like the link for the new windows modo-13-14 studio is bringing up the linux version?
jwfvr
Postby face_off » Fri May 07, 2021 12:27 am
face_off Fri May 07, 2021 12:27 am
jwfvr wrote:it seems like the link for the new windows modo-13-14 studio is bringing up the linux version?
The download link has been now been fixed.
Postby jwfvr » Fri May 07, 2021 12:39 am
jwfvr Fri May 07, 2021 12:39 am
Im still getting the same file -
jwfvr
Postby face_off » Fri May 07, 2021 12:52 am
face_off Fri May 07, 2021 12:52 am
The forums reverted my change. Try again please.
Postby jwfvr » Fri May 07, 2021 1:01 am
jwfvr Fri May 07, 2021 1:01 am
got it! thank you!
jwfvr
Postby yoshikai » Fri May 07, 2021 1:17 pm
yoshikai Fri May 07, 2021 1:17 pm
Hi Paul.
Thanks for the update!
I have tried the Octane Greyscale Vertex Attribute and it works great for normal polygon objects, but the weight maps I set for curves do not load correctly.
Is there any chance in the future that the curve weight map will load correctly?
It would be very helpful if the curve weight map could be loaded correctly.
A simple scene is attached.
curve weightmap.zip
(248.21 KiB) Downloaded 188 times
yoshikai
Postby face_off » Fri May 14, 2021 10:29 am
face_off Fri May 14, 2021 10:29 am
I have updated the installers at the top of this thread with:
2020.2.3.171
- Color Correction->Brightness has a maximum value of 100 again
- Fixed issue where sometimes an Area or Point Light would not auto-fresh
- Fixes the issue where images could not be saved if a colorspace was specified.
Postby face_off » Fri May 14, 2021 10:30 am
face_off Fri May 14, 2021 10:30 am
yoshikai wrote:Hi Paul.
I will investigate if this can be done.
Postby yoshikai » Sat May 15, 2021 12:24 am
yoshikai Sat May 15, 2021 12:24 am
face_off wrote:I will investigate if this can be done
Thank you.
I appreciate it.
yoshikai
PreviousNext
Return to Foundry Modo
Users browsing this forum: No registered users and 7 guests
Tue Apr 23, 2024 9:28 pm [ UTC ]
