funk wrote:Yep that sounds right. 2020 is still an experimental build (alpha/beta), so things can change. These changes are in the octane core (see the standalone thread) so the plugins have to follow.
Obizzz wrote:funk wrote:Yep that sounds right. 2020 is still an experimental build (alpha/beta), so things can change. These changes are in the octane core (see the standalone thread) so the plugins have to follow.
I know and it makes sense to make it compatible with 2019. Not blaming anyone else than myself for the extra work.
I did not see any note about this in the XB3 standalone thread though. A search for Radius Maps only takes me to my own post.
Hi - can you send me the scene please?GOTHACOM wrote:Hello, I have a simple scene with a vdb item attached to a volume item, and while rendering the animation I get the error "Duplicate material Volume:Volume in AppendMaterialNode" at each frame: the error message stops the renderi every time it popups. Is there a way to get rid of this message?
Octaner for modo 2020.1.0.159
Thanks.
G
face_off wrote:Hi - can you send me the scene please?GOTHACOM wrote:Hello, I have a simple scene with a vdb item attached to a volume item, and while rendering the animation I get the error "Duplicate material Volume:Volume in AppendMaterialNode" at each frame: the error message stops the renderi every time it popups. Is there a way to get rid of this message?
Thanks.
G
This is a problem with recent versions of Substance. It was reported to the Substance devs about a year ago, but I am not aware of any resolution yet. May I suggest you report the problem on the Substance forums.paberu wrote:Substance plugin compatibility looks to be broken with 2020, example below. It seems to be working fine if I manually import and assign all the maps.
Modo 14, Substance 2.7.3 and octane 2020 rc2.
Users browsing this forum: No registered users and 7 guests
