Bug: Material picker with shift camera
Forums: Bug: Material picker with shift camera
Postby quilmequick » Thu Jun 07, 2018 11:00 am
quilmequick Thu Jun 07, 2018 11:00 am
HI Paul,
Just reporting a bug, when you use the material picker on a shift camera it samples the non shifted image. So you have to click around and guess where the non shifted image would be to pick the material.
Quil
quilmequick
Re: Bug: Material picker with shift camera
Postby quilmequick » Thu Jun 07, 2018 1:32 pm
quilmequick Thu Jun 07, 2018 1:32 pm
Hmmm....after some investigation it might not be the shift lens, but my material picker is still offset. Also probably related -- but the bottom of my image doesn't show in the octane render window but when I export an EXR it's there. The bottom of the image is also visible in the modo viewport, obviously.... Hmmm time to restart modo. Ok still having the issue after a restart. Perspective correction is off, so it's not that.
I have previously been using shift cameras in my scene, but the camera I'm using now doesn't have shift.
So basically my Octane render viewport is cropping the bottom of my composition of, but not during export, this is also offsetting the material picker. I'm stumped maybe it's not a bug and im just doing something wrong. I can work round it but maybe worth looking into.
See the red line in the image below.
https://imgur.com/a/xhucGpL
quilmequick
Postby face_off » Fri Jun 08, 2018 1:39 am
face_off Fri Jun 08, 2018 1:39 am
Hi
What OS, Modo and Modo plugin versions are you using pls?
On the Exported OR Image, did you add the red line, or the plugin?
Postby quilmequick » Fri Jun 08, 2018 11:53 am
quilmequick Fri Jun 08, 2018 11:53 am
HI Paul,
Yes I added the red line just to show where the viewport was cropping.
The render region picker is also offset.
Windows 10
OctaneRender 3.08 (3080015)
Modo 10.2.v1 126693
Edit...I think the issue seemed to go away after adding in a new camera to the scene and rendering through it, then when I switched back to the original camera (that had the issues) the issues are gone. But it did seem that some information about shift cameras is maybe being retained, even when shift values have been deleted.
quilmequick
Postby face_off » Sat Jun 09, 2018 1:11 am
face_off Sat Jun 09, 2018 1:11 am
Thanks. Could be a corrupted Modo scene. If it happens on another scene, pls let me know.
Return to Foundry Modo
Users browsing this forum: No registered users and 22 guests
Fri Apr 19, 2024 9:19 pm [ UTC ]
