modo fur and use render cache
Forums: modo fur and use render cache
Re: modo fur and use render cache
Postby TStudio » Tue Nov 21, 2017 1:47 pm
TStudio Tue Nov 21, 2017 1:47 pm
Thank you Paul! I will see if "W Coordinate" will work for my needs now. It is good to know that it will be in modo sooner than later !
Will you be able to add more modo fur features in future Octane versions? Like applying texture over individual strip of poligons using special modo projection "Implicit UV" ? Like in this file:
https://www.dropbox.com/s/r6vro770rtaqfcu/Feathers.zip?dl=0
TStudio
Postby TStudio » Wed Nov 22, 2017 9:51 am
TStudio Wed Nov 22, 2017 9:51 am
Hi Paul.
Here is my result of wcoordinate ... or I`m doing it wrong ?
My modo is 902 (108604) octane Standalone (3,07) Plugin verison (3_7_0_125).
Scen is here for download:
https://www.dropbox.com/s/xp522xba5mr39z6/W%20coordinate%20problem.zip?dl=0
TStudio
Postby face_off » Sat Nov 25, 2017 11:21 pm
face_off Sat Nov 25, 2017 11:21 pm
https://www.dropbox.com/s/r6vro770rtaqf ... s.zip?dl=0
I think this will be difficult to do unless you can get Modo to generate UV's for each individual feather strip. Using the render cache, the plugin picks up the UV's from the render cache, and no feather specific UV's are supplied when Implicit UV is used (Modo is instead providing the "Texture" UV map coordinates.
Postby TStudio » Sun Nov 26, 2017 11:25 am
TStudio Sun Nov 26, 2017 11:25 am
Thank you for the answer Paul. I will see if this will work in modo.
TStudio
Previous
Return to Foundry Modo
Users browsing this forum: No registered users and 16 guests
Wed Apr 24, 2024 6:39 am [ UTC ]
