Saving and reusing presets materials
Forums: Saving and reusing presets materials
Postby andreaborlo » Sun Oct 23, 2016 2:51 pm
andreaborlo Sun Oct 23, 2016 2:51 pm
Can somebody please point me in the right direction regarding saving and reapplying materials presets with the modo plugin.
I have seen that in the Cinema plugin I can save presets in the Local Live Database so that they can later be loaded in a different scene.
Is it possible to do this in the Modo version?
If that is not the case can I export them In the standalone version and save in the local database from there? because I tried that but I can't
succeed in saving anything in the LDB even from there.
What is the correct way to do this?
Thanks a lot.
Andrea
andreaborlo
Re: Saving and reusing presets materials
Postby face_off » Sun Oct 23, 2016 10:30 pm
face_off Sun Oct 23, 2016 10:30 pm
Postby andreaborlo » Mon Oct 24, 2016 4:09 pm
andreaborlo Mon Oct 24, 2016 4:09 pm
Thanks Paul!
andreaborlo
Postby joshkitney » Wed Nov 23, 2016 10:40 am
joshkitney Wed Nov 23, 2016 10:40 am
Oh what I would just love is that I make a material and select the node, right click and "save material to LiveDB".
None of this command line BS.
Sorry to be a nag Paul, is it Modo that is fighting you or are you just too busy to make it so?
P-L-E-A-S-E
Cheers
josh
i7 5960X Haswell-E 8-Core OC 4.2GHz // 2x GTX 980 Ti Superclocked+, 1 GTX 670 // 64GB's // Windows 10
joshkitney
Postby face_off » Wed Nov 23, 2016 11:16 am
face_off Wed Nov 23, 2016 11:16 am
I get a bit worried about adding a button for every command, that it will clutter the UI and be confusing to users. You can add a button yourself - just tweak the Modo UI via the Form Editor. If a critical mass of users want a button added for this, I can do it - but someone needs to send me an icon for it :-) And I think you are referring to the octane.exportMaterial command - which saves to the LocalDb rather than LiveDb (assuming you save the ORBX in the right place).
Postby haffy » Wed Apr 26, 2017 6:14 pm
haffy Wed Apr 26, 2017 6:14 pm
I would love this too :)
Btw do we need to install the LiveDB to have access to the LocalDB? I avoid this thou I think It's a mess to install the LiveDB.. Or maby I am lazy.
3D Generalist.
haffy
Postby joshkitney » Wed Apr 26, 2017 7:15 pm
joshkitney Wed Apr 26, 2017 7:15 pm
I think to have a system (button) to save presets/materials with an icon is a good idea. This saves the user from the command line crap and puts more "creation time" in making magic.
It's a big bloody drag to have a system where you have to jump through hoops just to have two spheres in two different documents shaded with the same material.
I want a button Paul... Make it so!
joshkitney
Postby face_off » Thu Apr 27, 2017 12:04 am
face_off Thu Apr 27, 2017 12:04 am
No - you don't need to install the LiveDb to access the LocalDb. Also - you you really want a LiveDb material, you can just load it in Octane Standalone and copy/paste into the Modo plugin.
Pls see my conditions for adding such an icon above - specifically regarding supplying an icon image.
Postby rrbarb » Thu Apr 27, 2017 1:46 am
rrbarb Thu Apr 27, 2017 1:46 am
Leave the issues that the user cannot easily influence to Paul. As for this request, use the forms editor, make a pie menu with the Octane items you use the most and call it a Button. Contribute to your own cause, cause you can!
./rrb
rrbarb
Postby haffy » Thu Apr 27, 2017 7:09 am
haffy Thu Apr 27, 2017 7:09 am
Found the "Save preset" and it works fine, would love if there was an checkbox like "Save textures with material" that made a folder for the material and saved the textures there too.
3D Generalist.
haffy
Next
Return to Foundry Modo
Users browsing this forum: No registered users and 22 guests
Thu Apr 25, 2024 1:52 pm [ UTC ]
