OctaneRender 3 for Modo [OBSOLETE]
Forums: OctaneRender 3 for Modo [OBSOLETE]
Re: OctaneRender 3 for Modo [TEST and STABLE]
Postby Uhlhorn » Wed Dec 13, 2017 11:36 pm
Uhlhorn Wed Dec 13, 2017 11:36 pm
face_off wrote:
If you check the release notes, it tells you the exact Octane version that was used.
Ah, okay. Thank You.
But however, can You please always link the correct version? I am not an every day Octane user and I have to spent a lot of time to figure out the correct version and where to download. And after installing it will not run. So I have to investigate where exactly the problem is. Updating is always a big issue for me! And a link to all corresponding versions would be a great help for me (and other users too, I think). Just download and install.
Uhlhorn
Postby face_off » Thu Dec 14, 2017 12:07 am
face_off Thu Dec 14, 2017 12:07 am
I'm sorry - but I have tried this in the past and it created a lot of confusion for users due to me not keeping the links to the appropriate Octane Standalone version up to date. The current method of listing the Octane Version in the release notes is a more reliable and robust method.
Postby Uhlhorn » Thu Dec 14, 2017 11:08 pm
Uhlhorn Thu Dec 14, 2017 11:08 pm
Okay. Than I have to continue to search …
Uhlhorn
Postby Uhlhorn » Mon Jan 08, 2018 8:08 pm
Uhlhorn Mon Jan 08, 2018 8:08 pm
face_off wrote:For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Hmm, okay. I downloaded the Octane Modo plugin 3.07.0.125. And I can’t find a version 3.07.0 of the Modo plugin.
And I can only find a standalone Octane version 3.07.0. A standalone version 3.07.0.125 of Octane is not available.
3.07.0.125 is not exactly 3.07.0!
Modo Plugin: 3.07.0.125
Standalone: 3.07.0
This does not match exactly! :-( Now, how can I match this exactly?
Uhlhorn
Postby Hesekiel2517 » Mon Jan 08, 2018 9:19 pm
Hesekiel2517 Mon Jan 08, 2018 9:19 pm
Hey there,
maybe i don't understand your problem exactly. But the Release Notes say:
3.07.0.125 (3-Nov-2017)
- Built with Octane 3.07
The Modo Plugin is build with the Octane version 3.07 and the Plugin Version is 0.125 (please correct me if i'm wrong). So the corresponding Standalone Version is 3.07.
So it's possible to have multiple Modoplugins which are build with the same Octane Standalone Version (for example to correct non octane related issues).
Hesekiel2517
Postby Uhlhorn » Mon Jan 08, 2018 11:14 pm
Uhlhorn Mon Jan 08, 2018 11:14 pm
Hesekiel2517 wrote:The Modo Plugin is build with the Octane version 3.07 and the Plugin Version is 0.125 (please correct me if i'm wrong). So the corresponding Standalone Version is 3.07.
Perhaps I have an other understanding of the word „exact“. „Exact“ means exactly and not almost exactly.
Exact means correct in every detail.
Collins Dictionary
Uhlhorn
Postby Hesekiel2517 » Tue Jan 09, 2018 5:13 am
Hesekiel2517 Tue Jan 09, 2018 5:13 am
ok, another try:
There are 3 kinds of Software involved:
Modo, Octane and the Plugin which connects both. Modo has a Software Version (11.2, 11.11, 10.2 etc.). Octane has a Version (3.07, 3.06, 3.05). The Plugin has a Version (0.123, 0.124, 0.125). So the Pluginversion has nothing to do with the Octane Version. You need the Octaneversion the Plugin is build with.
So when the Release Note say:
You need to install Standalone Version 3.07 to make Network Rendering work.
Again please correct me if i'm wrong on this.
Hesekiel2517
Postby Uhlhorn » Tue Jan 09, 2018 6:26 pm
Uhlhorn Tue Jan 09, 2018 6:26 pm
Okay, but then it’s not „exact“ the version. Then there are two versions, an Octane engine version and an plugin version.
In autumn last year I tried to install a newer version, because I thought it is as you say. But I was not able to get this running.
So I spent a whole day in trying anything to get this running, without success. At the end, I returned to my previous version.
Uhlhorn
Postby face_off » Wed Mar 07, 2018 4:29 am
face_off Wed Mar 07, 2018 4:29 am
I have updated the TEST release at the top of this thread with:
3.08.0.127 (7-Mar-2018)
- Compiled with Octane 3.08 RC1
- Resolved issue where the Modo FOV was not being taking into account when camera projections with film offsets
- Resolved issue there animated curves were not rendering
- Resolved issue where the physical sun was not being set in the Octane Environment node after frame 0 when rendering an animation
- Added Toon Light controls to the Light package
This is Windows-only at this stage. I will add OSX and Linux builds once they are released by OTOY.
Postby funk » Wed Mar 07, 2018 6:51 am
funk Wed Mar 07, 2018 6:51 am
Thanks Paul
Win10 Pro/ Ryzen 5950X / 128GB / RTX 4090 / MODO
funk
PreviousNext
Return to Foundry Modo
Who is online
Users browsing this forum: No registered users and 25 guests
Thu Apr 25, 2024 4:36 pm [ UTC ]
