Hi Paul,
Is it possible to insert 2 buttons as standard in the modo-octane plugin for octane.saveAnimation and octane.createUDIM ? These commands seems very useful yet they are not in the ui.|
Cheers,
Vlad
There are more new buttons on the way - so perhaps raise this again in a month once you see the next commands. In the meantime, you can add buttons for these commands yourself.Is it possible to insert 2 buttons as standard in the modo-octane plugin for octane.saveAnimation and octane.createUDIM ? These commands seems very useful yet they are not in the ui.|
face_off wrote:There are more new buttons on the way - so perhaps raise this again in a month once you see the next commands. In the meantime, you can add buttons for these commands yourself.Is it possible to insert 2 buttons as standard in the modo-octane plugin for octane.saveAnimation and octane.createUDIM ? These commands seems very useful yet they are not in the ui.|
You can remember some of your settings between Modo901.CFG deletes with https://docs.otoy.com/Modo/?page_id=1091. It is necessary to delete your Modo*.CFG file in order to pick up some of the new plugin features from time to time.but since this is a 2 release a month, it is not fun loose my configs in octane render, and ui I setup.
Users browsing this forum: No registered users and 13 guests
