Page 6 of 12
Re: Modo Plugin Roadmap
Posted:
Thu Feb 12, 2015 11:25 pm
by ch0pper
thanks for the tip will check it out
Posted:
Fri Mar 27, 2015 9:34 pm
by diegomaricato
Hi Paul!
I really apreciate the work you´ve been doing for usa.
There is one thing I miss in Modo, not only in the Octane plugin, and I believe it is a limitation of Modo, so I would like to ask if is possible (in the future) to implement sliders like the Cinema 4D (attached). It is much easier to use than the Modo´s arrows. (the Graph Editor has sliders!)
Vray for Modo also has sliders, but I think it is and external app.
Thanks again.
Diego
Posted:
Sun Mar 29, 2015 2:03 am
by face_off
Hi Diego
Yes - the absence of sliders is a general Modo UI issue rather than specific to the plugin. Adding sliders to the plugin for the current version of Modo is not possible, since Modo manages the UI for the plugin properties/channels (and does not support sliders). Hopefully in the future it will be possible in Modo to add sliders (since I miss them too).
Posted:
Sun Mar 29, 2015 10:40 am
by funk
diegomaricato wrote:Vray for Modo also has sliders, but I think it is and external app.
Yes, the Vray Frame Buffer (where rendering happens) is really an external application. Vray's modo UI has no sliders that look like this.
Just in case you missed it, modo's sliders can be clicked, held and dragged so they really do the same thing.
diegomaricato wrote:the Graph Editor has sliders!
Um... That's a timeline with keys.
Posted:
Sun Mar 29, 2015 2:37 pm
by diegomaricato
Thanks Paul and Funk for your answers!
Yes, you can click and drag, I just miss the precision of the sliders =), since sometimes you just don´t know if the maximum setting is 10 or 1000.
Maybe I´ll just edit in the forms and add the text in the tooltip or the label, it could help.
Thanks again!
Posted:
Mon Jul 13, 2015 11:24 am
by Flyx
Hi !
Just wanted to know if the procedural compatibility from modo is still on the road ?
After a long time away from octane i'm testing the demo on modo and find it very good, but i miss all the possibility of modo's procedurals. Of course you can still bake them but sometimes it's very long...
So are they still on the road map and is the plugin will be able to mix them like they are in the shader tree ( using layerad procedural for example, with opacity etc...) ?
Posted:
Mon Jul 13, 2015 11:59 am
by face_off
Hi. Yes, I agree that baking is not really viable. Implementing full support for Modo procedural textures requires enhancements to the Modo API (so that plugins can access the procedural bitmap info) - so the more people that request this from TF, the more likely it is to happen. Partial support may be possible by replicating the Modo procedural textures using Octane nodes, but this is not likely to be particularly accurate. Otoy has also announced that Octane 3 will support OSL (open shader language) which is going to open up a great number of possibilities for people to write their own shaders.
Hope that helps.
Posted:
Mon Jul 13, 2015 12:26 pm
by Flyx
Ok thanks i will continue with baking for now
I think i saw somewhere that sustances were compatible ? Can remember and find where
And just one last thing ^^ it's about a bug but i don't want to create a new thread just for that, when i put a texture to roughness in the shader tree nothing happens in octane, the same texture within an overrride gives good result, but in the shader tree it doesn't work don't know why...tried roughness, specular roughness, well everything with roughness in the name. The same texture show's up when i switch to something like diffuse color
Posted:
Wed Jul 15, 2015 7:52 am
by face_off
Yes, at the moment you need to do this in an Octane Override. However support for images in more Effect types is on the TODO list for the net release.
Posted:
Wed Aug 19, 2015 8:24 am
by Flyx
What is the estimation for the next release with the "updated" on the fly conversion of map ? ( roughness, luminous^^ etc..) it's one of the only thing that is bothering me, i would like to be able to skip override as much as i can ^^ at least for "simple" material
