by timbarnes » Fri Jul 16, 2010 10:51 pm
timbarnes
Thanks for keeping at it...
I'm finding cases where the .obj is not clean enough to load into Octane successfully, but if I open it in Accutrans 3D and then save it out, the saved file opens OK. I think it may have to do with ngons or stray vertices, because Accutrans complains, but doesn't crash.
Do you have any control of the .obj you're writing out? I guess I may need to run a mesh cleanup script before I run the Octane plugin?
It would be nice to avoid these extra steps with texture gathering etc.
The .obj file is over 100Mb: do you want to see it (or the modo file, which is over 60Mb, I think). By the way, I'm using modo 401 SP5 64 bit on Windows 7 Pro.
Regards,
tim
Mac Pro 3,1 / Lion / 14G RAM / ATI HD 2600 / nVidia GTX 470
i5-750 / Windows 7 Pro 64bit / 8G RAM / Quadro FX 580
Revit 2011, SketchUp 8, Rhino
