i just found out, that there is a new option to export animations with only transforms. This works great for cameraanimation, but does not work for objects. Is there a trick? Objects stay static in Octane Standalone no matter what I try.
"So only use this export command if there are animated vertices or animated deformers/meshops in the scene. If you only want to export a camera animation, then tick Kernel->Animation->Camera Motion Blur and use the Export Frame option from the Export Render button. If you want to export both a camera animation and geometry transform animations, then tick Kernel->Animation->Object Motion Blur and use the Export Frame option from the Export Render button. "
All the best
Edit: latest Plugin, latest Modo by the way
