portnicki wrote:I get everytime I just save my scene in the lates plugin.
face_off wrote:I do not get the error you have reported when I load that scene.
item.name Render
Thanks - for the time being, the Render item will need to be called "Render". Renaming it to anything will result in an error.funk wrote:Good catch. You can rename the render item by selecting it and using this command:
- Code: Select all
item.name Render
This will fix it, although the plugin's internal commands should be getting the render item via an SDK method rather than relying on the name to be "Render"
Users browsing this forum: No registered users and 13 guests
