OctaneRender 4 for Modo [TEST and STABLE]
Forums: OctaneRender 4 for Modo [TEST and STABLE]
Re: OctaneRender 4 for Modo [TEST and STABLE]
Postby MrFurious » Fri Jan 18, 2019 11:42 am
MrFurious Fri Jan 18, 2019 11:42 am
Is it possible to have 2 different versions of the plugin installed at the same time.. for 2 different versions of Modo? (902 & 12.2 v1)
Cheers,
Dino.
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
MrFurious
Postby SreckoM » Sat Jan 19, 2019 4:15 pm
SreckoM Sat Jan 19, 2019 4:15 pm
Out of core geometry is not implemented into Octane for Modo version? I only see Out of core texture options in settings.
SreckoM
Postby face_off » Sun Jan 20, 2019 4:50 am
face_off Sun Jan 20, 2019 4:50 am
Out of Core Textures /includes/ out of core geometry. I will change the text in the plugin to reflect this.
I don't think this is easily possible unless you manually copy one of the plugins into a different folder and adjust the CFG file accordingly.
Postby SreckoM » Sun Jan 20, 2019 4:25 pm
SreckoM Sun Jan 20, 2019 4:25 pm
Thanks Paul!
SreckoM
Postby face_off » Fri Jan 25, 2019 3:13 am
face_off Fri Jan 25, 2019 3:13 am
Hesekiel2517 wrote:Hey there,
i tried the new light linking feature and want to say thank you for implementing this. Works really well!
Would it be possible to link the light also by Material and not by Mesh?
I don't think this is supported by Octane, since the Light Pass Mask is attached to a geometry item, not a material.
Postby face_off » Wed Jan 30, 2019 5:51 am
face_off Wed Jan 30, 2019 5:51 am
I have updated the STABLE installer at the top of this thread with:
4.02.0.139
- Compiled with Octane 4.02
- Fixed bug when moving a Point Light with no emitter geometry attached
- Fixed bug where changing a Constant item in the Shader tree was not live updating the Octane viewport
- Added "Linear Space Invert" to RGB Image, Alpha Image, Float Image, Instance Color and Baking Texture nodes
- Fixed issue where changes to nodes in the schematic such as the Gradient node were not live updating in the Viewport
Postby MrFurious » Wed Jan 30, 2019 6:02 am
MrFurious Wed Jan 30, 2019 6:02 am
no problem, thanks Paul.
Dino Inglese
CG Artist
Melbourne Australia
MrFurious
Postby funk » Wed Jan 30, 2019 7:43 am
funk Wed Jan 30, 2019 7:43 am
Thanks Paul
Win10 Pro 64 / Core i7-975 3.33GHz / 12GB RAM / GTX 1080 Ti + GTX 670 / 2x1920x1200 / MODO 12
funk
Postby Tharso » Mon Feb 11, 2019 7:14 pm
Tharso Mon Feb 11, 2019 7:14 pm
When we will get octane for modo 13 beta?
Tharso
Postby face_off » Tue Feb 12, 2019 12:07 am
face_off Tue Feb 12, 2019 12:07 am
The current version of the plugin should run with Modo13, however I am aware of some Modo13 issues that cause problems in the plugin, so I would not recommend using the plugin with Modo13 yet.
PreviousNext
Return to Foundry Modo
Users browsing this forum: ZaRooster and 3 guests
Wed Jul 17, 2019 2:31 pm [ UTC ]
