Post Processing Not Working
Forums: Post Processing Not Working
Postby mikegem » Wed Jul 07, 2021 12:24 pm
mikegem Wed Jul 07, 2021 12:24 pm
Preview or final Post processing not working. If I enable just the post processing pass I can see the effects, but when I go to combined there is no effect. If I use the compositor and combine post layer with image I can see the effect in final render.
Post_Not_Working.blend
(34.04 MiB) Downloaded 201 times
mikegem
Re: Post Processing Not Working
Postby linograndiotoy » Wed Jul 07, 2021 9:54 pm
linograndiotoy Wed Jul 07, 2021 9:54 pm
You should disable Post Process in the Render Passes. If you keep it on, Post Process will be exported in a separate pass (you don't want Post Process to be also in the "main" pass in that case).
linograndiotoy
Postby mikegem » Thu Jul 08, 2021 2:30 pm
mikegem Thu Jul 08, 2021 2:30 pm
WELL ALLLLLLLLLRIGHT!!! Thank You!! :D :D
mikegem
Postby linograndiotoy » Sat Jul 10, 2021 8:38 am
linograndiotoy Sat Jul 10, 2021 8:38 am
Sure!
linograndiotoy
Return to Blender
Users browsing this forum: No registered users and 25 guests
Thu Apr 25, 2024 2:00 am [ UTC ]
