linograndiotoy wrote:Maybe those settings work fine for you, but are not the best option.
1. Best Color Management settings:
* Display Device: sRGB
* View Transform: RAW
* Look: None
* Exposure: 0.0
* Gamma: 1.0
2. Go to camera tab in Properties window and enable Octane Camera Imager (Render mode)
3. Alternatively go to 3d view Properties panel (N key shortcut), locate Octane Camera Imager (preview Mode) and enable Override. This way all cameras will have the setting from this panel.
Camera Imager for preview should be set to sRGB.
Then is up to the user to decide to save the images in sRGB or Linear.
elsksa wrote:Hi,
https://www.elsksa.me/scientia/cgi-offline-rendering/octane-render-color-management-b3d may help.
It is strongly recommended to load Filmic OCIO. Octane alone, like any other renderer, does not include an advanced native solution to properly conform high dynamic range radiometrically linear data to "sRGB web ready", simply said. Without it, "visual flaws" will appear, more or less strongly, depending on the scene.
elsksa wrote:Ed O'Connell (llennoco) mentioned to enable the Octane output option to save the EXR directly.
