Surface Scatter: instance sizes from large to small?
Forums: Surface Scatter: instance sizes from large to small?
Postby pegot » Sun Apr 04, 2021 1:46 pm
pegot Sun Apr 04, 2021 1:46 pm
I’m fumbling around with Scatter on Surface trying to get feathers to cascade from large on top to small at the bottom. How can I achieve this? Using Blender’s particle system I can do that via weight painting and vertex groups. How can I do it with Octane’s geometry nodes? I imagine that is controlled somehow by the scale map but everything I try (gradient node, fall off node) effects the size of all the instances together.
Win 10
3.7Ghz i9 10900k / 64GB
ASUS STRIX Z490-E
PSU: PowerSpec 850Wd
RTX 3090 Asus Tuff
Network rendering:
Win 10
4.2Ghz i7 7700k / 64GB
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 Ti EVGA Hybrid
RTX 3080 ASUS Tuff
GTX 1080ti SC Black (wc)
pegot
Re: Surface Scatter: instance sizes from large to small?
Postby grimm » Sun Apr 04, 2021 5:29 pm
grimm Sun Apr 04, 2021 5:29 pm
For the geometry nodes you might try to use the point distribute and point instance nodes. You can find some good information here in Blender Guru's geometry node tutorial...
https://www.youtube.com/watch?v=52UYqe3 ... lenderGuru
It will definetely need a different setup for your scene.
Jason
Linux Mint 20 x64 | Nvidia GTX 980 4GB (displays) RTX 2070 8GB| Intel I7 5820K 3.8 Ghz | 32Gb Memory | Nvidia Driver 460.56
grimm
Postby pegot » Sun Apr 04, 2021 6:36 pm
pegot Sun Apr 04, 2021 6:36 pm
Thanks grimm. That was my first exposure to Blender's Geometry nodes and they look really neat. But I meant Octane's new scatter system (which appears in the Octane Geometry node drop down menu). I am trying to figure out how to adjust scale cascading from top to bottom using the Octane system. I did change the "Up direction" and "Front direction" modes to Point, but am still unable to figure out how to get the cascading scale (which is quite easy using Weight Painting and Blender's internal particle system).
Can any devs provide such instruction?
Win 10
ASUS STRIX Z490-E
RTX 3090 Asus Tuff
Network rendering:
Win 10
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 ASUS Tuff
pegot
Postby linograndiotoy » Wed Apr 07, 2021 1:51 pm
linograndiotoy Wed Apr 07, 2021 1:51 pm
For now you can only use Procedural or Image Textures to achieve this kind of control.
linograndiotoy
Postby pegot » Wed Apr 07, 2021 7:54 pm
pegot Wed Apr 07, 2021 7:54 pm
linograndiotoy wrote:For now you can only use Procedural or Image Textures to achieve this kind of control.
Can you show me an example of the node set up? I did try with both a grayscale image and various procedural nodes but could not get it working. Thanks!
Win 10
ASUS STRIX Z490-E
RTX 3090 Asus Tuff
Network rendering:
Win 10
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 ASUS Tuff
pegot
Postby linograndiotoy » Fri Apr 09, 2021 2:52 pm
linograndiotoy Fri Apr 09, 2021 2:52 pm
Consider you need an UV map on the mesh.
linograndiotoy
Postby pegot » Fri Apr 09, 2021 7:49 pm
pegot Fri Apr 09, 2021 7:49 pm
The mesh does have a UV map but still not getting a cascading change in size. How to set that up? Very easy in Blender's internal system using Vertex Weights. But would love to learn how to do this with Octane's amazing and faster system. Thanks!
Win 10
ASUS STRIX Z490-E
RTX 3090 Asus Tuff
Network rendering:
Win 10
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 ASUS Tuff
pegot
Postby linograndiotoy » Sat Apr 10, 2021 1:44 pm
linograndiotoy Sat Apr 10, 2021 1:44 pm
This should help.
Gradient_Scatter.blend
(890.78 KiB) Downloaded 173 times
linograndiotoy
Postby pegot » Sat Apr 10, 2021 11:25 pm
pegot Sat Apr 10, 2021 11:25 pm
linograndiotoy wrote:This should help.
Thanks lino - this is very helpful! I'll have to study and play around with it for a bit to see how to modify settings for my own particular scenarios. But it is a great resource. How are we expected to know how to do this stuff though in the absence of documentation and tutorials? I don't want to be a pain in asking how to use the program when I could just consult established on-line resources (I'd much rather be a pain in asking why such stuff isn't working :D )
Win 10
ASUS STRIX Z490-E
RTX 3090 Asus Tuff
Network rendering:
Win 10
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 ASUS Tuff
pegot
Return to Blender
Users browsing this forum: No registered users and 24 guests
Thu Apr 25, 2024 11:27 am [ UTC ]
