Rounded edge
Forums: Rounded edge
Rounded edge
Postby canderled » Wed Feb 06, 2019 9:27 am
canderled Wed Feb 06, 2019 9:27 am
Hello Guys
I can't figure out the setup to make the rounded edge work in blender. i tried lot's of options and setup but never got it to work.
if i just export the model in obj with smoothing group and rendered it in standalone, it work perfectly out of the box.
I'm using the latest versions 2018.1 rc3.
In standalone:
Standalone render
best i got in blender with rounded edges:
Blender render
canderled
Re: Rounded edge
Postby J.C » Thu Feb 07, 2019 7:32 pm
J.C Thu Feb 07, 2019 7:32 pm
Did you enable smoothing in material settings?
CPU – i7 8700k 4.8Ghz + 64GB RAM, GPU – 2xGTX 980 Ti, 1xGTX 970
System – OS X 10.12.6, Windows 10, Octane 4/2018, Blender Plugin 16.x.x and 17.x
J.C
Re: Rounded edge
Postby canderled » Fri Feb 08, 2019 3:36 pm
canderled Fri Feb 08, 2019 3:36 pm
Yes, i tried with and without smoothing in the material, i never got it to work correctly :/
canderled
Re: Rounded edge
Postby J.C » Fri Feb 08, 2019 4:17 pm
J.C Fri Feb 08, 2019 4:17 pm
If it's not material smoothing then it looks like a mesh issue. Go to edit mesh mode and check if the edges have unnecessary weights assigned.
J.C
Re: Rounded edge
Postby ChrisH » Sat Feb 09, 2019 9:52 pm
ChrisH Sat Feb 09, 2019 9:52 pm
It seems that you can either have rounded edges OR Smooth shading (Smooth overrides Rounded Edges) and Rounded Edges don't care about the angles between faces.
Here's my test (and the difference in shader settings):
And the same scene in Octane Standalone:
It seems that you have two options:
  • Use different materials for different objects/meshes (one for Rounded Edges, one for Smooth)
  • Use a bevel modifier on the object (giving you control over which angles should be beveled)
NB: Rounded edges doesn't work with Auto Smooth.. :(
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Stand Alone + Blender Plugin user
ChrisH
Re: Rounded edge
Postby J.C » Sun Feb 10, 2019 6:11 pm
J.C Sun Feb 10, 2019 6:11 pm
Octane implementation of Rounded Edge is working ok only on meshes with flat surfaces. For other cases the best would be to use Bevel modifier with edge split modifiers to preserve mixed flat and smooth surfaces.
According to the developers Octane 2018.1 should have it improved.
J.C
Return to Blender
Tue Jun 18, 2019 8:39 am [ UTC ]
