Normal is not working properly
Forums: Normal is not working properly
Postby Yichen_Dou » Tue Jul 24, 2018 3:54 am
Yichen_Dou Tue Jul 24, 2018 3:54 am
I cannot say this is an bug, but I hope the result can be promoted.
The object above the surface plane is seperated from the surface by using Shrinkwrap and DataTransfer modifiers with corresponding vertex groups. In the viewport, it seems like two objects are connected. But Octane render dosenot give correct response, and even regardless of the sharp edges
# Viewport
# Octane
0000.blend
(1001.86 KiB) Downloaded 190 times
OS:Windows 10 Pro, 64-bit
CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz Quad
RAM: 32.00 GB
Graphic Card:NVIDIA GeForce GTX 1060 6GB
Yichen_Dou
Re: Normal is not working properly
Postby J.C » Tue Jul 24, 2018 7:00 pm
J.C Tue Jul 24, 2018 7:00 pm
Looks like it's Octane issue. Cycles looks better but after adding Subdivision modifier.
It would be better if you modelled it properly to avoid such issues.
System – Windows 11
J.C
Postby linograndiotoy » Mon Aug 27, 2018 3:56 pm
linograndiotoy Mon Aug 27, 2018 3:56 pm
BlenderOctane still can't "see" the effect of the Data Transfer Modifier.
It would be very important to have it fixed (developers are aware of this, and it's on their ToDo list).
linograndiotoy
Return to Blender
Users browsing this forum: No registered users and 16 guests
Fri Apr 19, 2024 10:12 pm [ UTC ]
