Render passes coming out white or black
Forums: Render passes coming out white or black
Postby OutOfTime007 » Fri Jul 21, 2017 11:07 am
OutOfTime007 Fri Jul 21, 2017 11:07 am
Hello,
I have set up a model with some render passes and they keep coming out white or black. The preview mode looks correct, but the final renders are just black or white.
Here is how I have set it up. What am I doing wrong?
Render Passes setup with Z-depth in preview:
Final render with depth selected:
OutOfTime007
Re: Render passes coming out white or black
Postby DigiChuckle » Tue Jul 25, 2017 5:54 am
DigiChuckle Tue Jul 25, 2017 5:54 am
In my experience Z depth particularly can behave like this because their value ranges are typically very high (in the thousands sometimes). I can't give you the exact technical explanation, but it has to do with wold scale and the size of your objects and scene.
All info is probably in there, you just can't see it (in 32 bit, white is more than white, and black is more than black). You could bring the Z pass in, say, Blackmagic Fusion, and perform a Depth Blur on your beauty render, adjust the Z scale (you'll probably have to lower it very very much).
Win10 Pro | Z620 | 2x 8 core Xeon 2.2 Ghz | 64 GB ram | Quadro K4000 + GTX 1060
DigiChuckle
Postby OutOfTime007 » Wed Jul 26, 2017 2:07 pm
OutOfTime007 Wed Jul 26, 2017 2:07 pm
I think I understand what you mean, but I think it might be something else. I am not using any weird scaling in my model. The whole scene is no more than a few Blender units in size.
It is not just the Z pass that comes out like this, it is also when I try using diffuse and other passes that they come out black or white. The weird thing is that they all look like what I would expect in the preview render, but in the final render they are all messed up. So I would think that is should work directily in Octane.
I have never tried using Blackmagic Fusion. It looks pretty cool, downloading the free version now.
OutOfTime007
Postby stijnwindig » Tue Nov 20, 2018 5:52 pm
stijnwindig Tue Nov 20, 2018 5:52 pm
Has anybody figured this out? I've recently started using the Blender plugin and all my render passes are black or white as well. No info in ém whatsoever, not even when exported to .exr.
Obviously, I'm doing something wrong, because no render passes would make the whole endeavour pretty useless, right?
Thanks in advance for any help on this!
stijnwindig
Postby J.C » Wed Nov 21, 2018 12:18 am
J.C Wed Nov 21, 2018 12:18 am
There are three solutions:
1. Use "Z-depth max" in passes settings or adjust rendered file exposure in post-production to get the correct looking z-pass.
2. Use "normalize" node in compositor on that z-pass.
3. Use Info-channel kernel to render z-pass with correct Z-depth max value in kernel settings.
System – Windows 11
J.C
Return to Blender
Users browsing this forum: No registered users and 20 guests
Tue Apr 23, 2024 11:12 am [ UTC ]
