Local material database and node names on export
Forums: Local material database and node names on export
Postby wakyak » Wed May 03, 2017 7:37 am
wakyak Wed May 03, 2017 7:37 am
Hi all!
Two questions:
1. Is a local material database supported within the Blender plugin?
2. When exporting to orbx all my nodes get charming sounding names like "0000000011334EA8", any way of making them retain their original tag?
Cheers /Erik
wakyak
Re: Local material database and node names on export
Postby abreukers » Fri May 12, 2017 5:35 am
abreukers Fri May 12, 2017 5:35 am
Hi Wakyak, I created a customized localDB, it's just a classic folder (or directory) for my octane materials which were created in BlenderOctane. Provided that the materials are applied to a mesh or something, I find that I can save my octane materials to a .blend file and place that file into the folder, and then if I want to load the same material, I just do a File>append and navigate to the folder where I stored the materials and select the .blend file. The .blend file lets you access the elements in it, and there is one folder within the .blend file that is reserved for the materials. You can then select the material from there.
i72630QM @ 2.00GHz | 6GB RAM | 2GB GeForce GT 540M | Win7 64bit
abreukers
Postby Marvez » Fri May 12, 2017 10:09 pm
Marvez Fri May 12, 2017 10:09 pm
why cant I import a material I setup in Octane standalone save as a ORBX local and then import into blender Octane? ; its something I can do easily with the Rhino plugin
I7 5820K 16MB RAM SSD850PRO GTX 970/780
Marvez
Postby pegot » Sat May 13, 2017 1:14 am
pegot Sat May 13, 2017 1:14 am
Apparently ORBX import is coming to all the plugins:
viewtopic.php?f=32&t=56768#p312265
Win 10
3.7Ghz i9 10900k / 64GB
ASUS STRIX Z490-E
PSU: PowerSpec 850Wd
RTX 3090 Asus Tuff
Network rendering:
Win 10
4.2Ghz i7 7700k / 64GB
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 Ti EVGA Hybrid
RTX 3080 ASUS Tuff
GTX 1080ti SC Black (wc)
pegot
Return to Blender
Wed Apr 24, 2024 9:55 am [ UTC ]
