Beta 2.2 RC1: Blender 2.55 Export Script testing thread
Forums: Beta 2.2 RC1: Blender 2.55 Export Script testing thread
Re: Beta 2.2 RC1: Blender 2.54 Export Script testing thread
Postby steveps3 » Sat Oct 23, 2010 7:48 am
steveps3 Sat Oct 23, 2010 7:48 am
Yep, that was the problem. Schoolboy error :(
(OS) Windows 7(64)
steveps3
Postby ycarry » Fri Oct 29, 2010 10:29 am
ycarry Fri Oct 29, 2010 10:29 am
Last working Octane exporter is with release 32430 for me.
I use r32732 and have error with the default="2" line 1009 ...
As Blender 2.55 is near coming...
how help to have this exporter? more error reporting? coding help?
ycarry
Postby haikalle » Wed Nov 03, 2010 10:56 am
haikalle Wed Nov 03, 2010 10:56 am
Hi! Thanks for this amazing script. I have one question thou. Does the script support bringging normal textures. It seams that what ever I do
it will be always bumb texture. Thanks.
haikalle
Postby harrisyu » Sat Nov 06, 2010 4:34 am
harrisyu Sat Nov 06, 2010 4:34 am
Hi!thanks for this great script.
after I try few times,I want to make a little change to it for my own use,
these are my modifition at line 1364:
#Use an existing octane ocs file
if projectFileAlreadyExists and not scene.oct_replace_project:
if scene.oct_animation_mode:#no -r ' -m %s.obj -r %s %s --output-png %s %s %s %s' (meshNode,objFile
command+=' -m %s.obj %s --output-png %s %s %s %s' % (meshNode,prefix,pngfile,camera_param,light_param,ocsFile)
else:
command+=' -m %s.obj %s %s %s %s' % (meshNode,prefix,camera_param,light_param,ocsFile)
I take "-r objfile.obj" out because it will overwrite all the materials settings I made before.
Seven 64bit | GTX 260 896mb | Phenom II X4 965 3.4GHz | 4GB DDR3
harrisyu
Postby bepea » Mon Nov 08, 2010 1:50 pm
bepea Mon Nov 08, 2010 1:50 pm
ycarry wrote:Last working Octane exporter is with release 32430 for me.
Im having the same problem in both blender 2.54 and 2.55
I have a win7 64bit python 2.7 and 3.1.2 installed and i cant get it to work...
Intel i3 530 3.0 ghz | 4 gb ddr3 ram(1600) | NVIDIA GeForce GTS 250 1gb | Windows 7 x64 / Ubuntu Linux 10.4.1 x64
bepea
Postby SnoWWolf » Tue Nov 09, 2010 2:29 pm
SnoWWolf Tue Nov 09, 2010 2:29 pm
Hi Enrico!
1. Exporting blender Groups would be great.
2. Particles converted to mesh not exporting.
3. When octane render engine is active in blender particle tab appears empty - have to switch to blender render to setup particles.
Where can i find a list of supported\planned to support blender object types?
Thank you! Keep the good work up!
E6600 | Win7 pro x64 | GTX 460 2gb | 4 GB | Blender 2.54 | python 3.1.2
SnoWWolf
Postby DavidT » Fri Nov 12, 2010 6:17 pm
DavidT Fri Nov 12, 2010 6:17 pm
I thought I would mention I'm having the same error in line 1009 (default="2"). I have tried a few different builds, including the new 2.55 beta, both 32-bit and 64-bit. I am running Windows 7 64-bit.
Windows 7 64-bit | GTX 470 | i7 920 | 12 GB
DavidT
Postby ycarry » Sat Nov 13, 2010 4:22 pm
ycarry Sat Nov 13, 2010 4:22 pm
This error can be solved by editing the script; see http://www.refractivesoftware.com/forum/viewtopic.php?p=38992#p38992.
ycarry
Postby enricocerica » Mon Nov 15, 2010 5:51 pm
enricocerica Mon Nov 15, 2010 5:51 pm
Hi there,
I'm going to proceed and try to publish something soon (don't expect too much for now anyway). I experimented some UV exporting issues but can't see anything similar reported here, is there anybody who experimented such problem ?
http://www.myline.be
enricocerica
Postby dave62 » Tue Nov 16, 2010 12:08 am
dave62 Tue Nov 16, 2010 12:08 am
hi,
yes i had several problems with not updated uv´s while export to octane using the 2.54 exporter.
While in blender the render looks fine, in octane it does not. (eg.: octane seems to ignore blenders clip/repeat mapping settings, it seems as alway use "repeat" for the image tex. Is there any clip/repeat/checker switch inside octane?)
So i had to do several refinements to the uv mapping, so i often got to correct uv in blender but the changes where not updated while export.
I am not shure why it didn´t work correctly but when i toggle back to blenderrenderengine it seems to update/export uv´s afterwards correctly.
Another strange thing: Inside this blender scene -if material is linked to "data", after export there is no mat available in octane. Material must be linked to object.. than it works!??
It all seems to depend on the blend file, or some special mat/link/mat usercount/relations in this scene i dont know.
I cant reproduce the discribed problems in the moment another scene, but it was a real pain to get it updated to octane wth my mk2 scene.
I never got any similar problems via obj export yet.
If you need further details about build ver etc i can tell you if i am at my workstation again.
thx dave
- Mint 10 64bit nvidia drv 260.19.29/cudatoolkit3.0 intel q6600, 4gbRAM, GTX470 1,2GB
- Mint 10 64bit/ Win7 64bit nvidia drv 260.19.29/cudatoolkit3.2 amd X6, 16gbRAM, 2x GTX580 3GB
->Octane 2.44/ Blender2.5x
dave62
PreviousNext
Return to Blender
Who is online
Users browsing this forum: No registered users and 3 guests
Sun Jan 24, 2021 9:06 am [ UTC ]
