Blender Exporter 2.02
Forums: Blender Exporter 2.02
Re: Blender Exporter 2.02
Postby kraken » Thu Mar 17, 2016 5:39 pm
kraken Thu Mar 17, 2016 5:39 pm
I'm getting a strange error.
Octane plug-in v1.16 on 2.76.0 : Output ocs: "E:\Media\projects\Furniture\Octane
\test.ocs"
Octane plug-in v1.16 on 2.76.0 : Output obj: "E:\Media\projects\Furniture\Octane
\test.obj"
Octane plug-in v1.16 on 2.76.0 : Output mtl: "E:\Media\projects\Furniture\Octane
\test.mtl"
Octane plug-in v1.16 on 2.76.0 : Unit Factor (rescaling): 1.0000
Octane plug-in v1.16 on 2.76.0 : Exporting frame #74
Traceback (most recent call last):
File "C:\Users\James\AppData\Roaming\Blender Foundation\Blender\2.76\scripts\a
ddons\octanerender\engine.py", line 101, in render
write_mtl(mtlTemp, mtl_list, scene, octane_render.export_copy_images)
ddons\octanerender\export.py", line 245, in write_mtl
filename = copy_image(mtex.texture.image)
ddons\octanerender\export.py", line 151, in copy_image
copy_file(fn_full,fn_dest)
ddons\octanerender\utils.py", line 115, in copy_file
file = open(source, 'rb')
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\Users\\Greg\\Deskto
p\\Free Models\\vase_collection\\maps\\vase001(color).jpg'
The last line basically is looking for a file that is in a path under a user that doesn't exist on my machine (my name is James).
The true path for this file is: E:\Media\models\Exotic Vase Collection\vase_collectionOBJ\maps\vase001(color).jpg
Either there is something in Blender pointing to the file creators metadata, or there is something in the plug-in defaulting to a path that is relative to the author. (or something else, I'm not smart enough to figure it out).
Octane won't launch so I am pretty much stuck.
James
Win 7 64bit Ultimate SP1
Blender 2.78
4x GTX980 Ti
NVidia Driver 373.06
Octane Server 3.03.4 v.11.2
Octane SA 3.03.4
Dual Xeon E5-2686
64 GB Ram
1TB SSD
AsRock EP2C612 WS
kraken
Postby kavorka » Thu Mar 17, 2016 9:45 pm
kavorka Thu Mar 17, 2016 9:45 pm
We have this happen a lot. You probably have a material that has a texture in its texture slot pointing to that image. We have this happen when we use objects we download online.
Check the texture slots of all your materials (although in this case, I would check any vases you have)
kavorka
Postby deadakos » Fri May 17, 2019 12:40 pm
deadakos Fri May 17, 2019 12:40 pm
Hello guys,
I tried to use this old Blender Exporter with the new Blender 2.8 version, but I'm getting error message.
Do you plan to update the exporter and instance exporter to run with 2.8?
i5 4590 | GIGABYTE Z97X-SOC FORCE | 32GB RAM | SSD 256GB | 3x GTX 1070 hybrid | Win10 64bit
deadakos
Postby ChrisH » Fri May 17, 2019 3:06 pm
ChrisH Fri May 17, 2019 3:06 pm
Hi!
This plugin/Add on is 5 years old and I'm not sure it will work with 2.79, I also doubt that it' compatible with the latest versions of Octane (4.0 or 2018.1), it definitely won't support new features.
As for it working with Blender 2.8 it would have to be (heavily) updated. 2.8 made some big changes to the API, so few to none 2.79 add ons work directly with 2.8, without any changes.
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
ChrisH
Postby linograndiotoy » Sun May 19, 2019 3:14 pm
linograndiotoy Sun May 19, 2019 3:14 pm
We can export ORBX files from Blender (the OTOY build) to Standalone, and the file gets instancing information stored correctly.
linograndiotoy
Previous
Return to Blender
Thu May 28, 2020 8:51 am [ UTC ]
