OctaneRender™ for Blender 1.20.1 - 1.1 beta [OBSOLETE]
Forums: OctaneRender™ for Blender 1.20.1 - 1.1 beta [OBSOLETE]
Re: OctaneRender™ for Blender 1.20.1 - 1.1 beta
Postby Alain » Sun Aug 18, 2013 6:32 pm
Alain Sun Aug 18, 2013 6:32 pm
aLeXXtoR wrote:But I think that the feature should stay - it's pretty handy.
What in detail is handy about it ? :-)
Kind regards
Alain
Intel Pentium 2.8 GHz 2 Cores, 8 GB RAM, GeForce GTX Titan 8GB, Blender 2.72b, Win 7 64 Bit
Alain
Postby myclay » Sun Aug 18, 2013 8:23 pm
myclay Sun Aug 18, 2013 8:23 pm
would it be ok to post questions here regarding material creation :?:
possible Bug? regarding Renderpreview;
When you have pressed Render and are using Renderpreview again and are still within the cam and scrolling out or in or panning to the side you can move the preview and you are somehow able to see the Pixel length of the image without the correct view from the camera
outside of Camera you won´t be able to pan or move the renderpreview anymore.
Win 7 64 | Geforce GTX570 + GTX260 | i7 3770 | 16GB
myclay
Postby JimStar » Sun Aug 18, 2013 9:02 pm
JimStar Sun Aug 18, 2013 9:02 pm
myclay wrote:would it be ok to post questions here regarding material creation :?:
Yes, I already wrote somewhere about it, perhaps just in closed alpha-testing threads... Will try to explain here.
You got this behavior due to camera view is shifted inside viewport. In this case there are only two ways for the plugin to fill the resulting gaps on sides of image
- change the FOV accordingly and render the much bigger image and not use rest of this image which is obscured by viewport
- get the same exact shifted region of the image from the engine
But the Octane engine, as you know - does not support region render so far. So, the second approach is unpossible.
And the first approach - can increase the render time by few times when the shift is high enough...
So, so far - it is only the compromise solution when you use viewport camera shifting...
JimStar
Postby JimStar » Mon Aug 19, 2013 3:29 am
JimStar Mon Aug 19, 2013 3:29 am
Alain wrote:The following seems to be a Bug too.
In some cases "Render Region" does render only a part of the selected region, see here:
Did not find out yet when this happens.
Edit:
And when I render with F12 then it renders something completely wrong, see comparison here:
Can you give me the scene, where it can be reproduced?..
JimStar
Postby aLeXXtoR » Mon Aug 19, 2013 4:52 am
aLeXXtoR Mon Aug 19, 2013 4:52 am
Alain wrote:What in detail is handy about it ? :-)
Hmm... Somewhy earlier I decided that it speeds up render time, calculating just the area. Now I see that it isn't so. So, my mistake.
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
aLeXXtoR
Re: OctaneRender™ for Blender 1.20.1 - 1.1 beta [OBSOLETE]
Postby JimStar » Mon Aug 19, 2013 4:53 am
JimStar Mon Aug 19, 2013 4:53 am
Next version HERE.;)
JimStar
Postby Alain » Mon Aug 19, 2013 8:17 am
Alain Mon Aug 19, 2013 8:17 am
Thanks.
I hope I will not be strain to mutch on your nerves this time ;-)
Kind regards
Alain
Alain
Previous
Return to Blender
Thu Aug 13, 2020 12:22 am [ UTC ]
