I need help exporting animation
Forums: I need help exporting animation
Postby Synthercat » Fri Jun 07, 2013 7:37 am
Synthercat Fri Jun 07, 2013 7:37 am
1) What the heck is going on with the exporter... how many braches & variation are there after the 1.19 version?
2) Blender changes built all the time... now I use 56945built and I don't do animation often (last animation was with other build... I get an error traceback blah blah blah (I WAS able to do animations before with the other builds)
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
Synthercat
Re: I need help exporting animation
Postby kavorka » Fri Jun 07, 2013 12:24 pm
kavorka Fri Jun 07, 2013 12:24 pm
I'm still on 2.65 because some people have said newer versions break the exporter and I dont need any of the new feature in Blender, since its mainly Freestyle and Cycles upgrades.
Animation is perfectly fine on this version.
kavorka
Postby octanetry » Tue Jul 09, 2013 8:11 pm
octanetry Tue Jul 09, 2013 8:11 pm
I do not understand the problem well
In any case I still use version 2.63 only for octane
and an update version for the rest
octanetry
Postby megacal » Thu Aug 08, 2013 6:23 am
megacal Thu Aug 08, 2013 6:23 am
Blender 2.68/Plugin 1.19/Octane 1.2 works for me. :)
You sure you have it set up right?
2 GPUs: Zotac GTX 580 1.5gb Amp! GPU for Octane....Galaxy 210 1gb for display
CPU: AMD Phenom II X4 955,3.2 ghz RAM: 8gb OS: Win7 64
megacal
Postby ChrisH » Wed Aug 14, 2013 11:24 am
ChrisH Wed Aug 14, 2013 11:24 am
Here's some general tips:
[list=][*]Try to only use the official/big releases of Blender for projects (RCs can be OK), if you don't need a certain feature that currently is in trunk.
[*]Don't switch version in the middle of a project (again: unless you really need to..)
[*]Don't throw away earlier versions of Blender when you switch to a new version.[/list]
New versions (especially from trunk etc) can be rather prone to have problems with plugins etc.
If you keep the "older" versions (at least those you know work fine), you have a backup if plugins don't play nice with the latest version.
This plugin (and most other plugins) are developed and maintained by enthusiast that do it whenever they have time over. You can't expect it to work with every single build of Blender (or even Octane..).
And Yoyoz is doing a great job!
I'm currently using 2.68a and the plugin seems to work "fine"(*). I only use it for animation, if I'm doing still renders in Octane I actually prefer to do it "manually" (exporting OBJ and setting it up in Octane), it's less hassle!
Last note: Again, this isn't an official plugin, so you have to take it for what it is. They are working on an official plugin (http://render.otoy.com/forum/viewtopic.php?f=7&t=27350) that will make things easier, but it wont really replace this plugin...
(* It was a bit troublesome, like crashing without reason when I tried to render the animation a few times and then magically it worked again..)
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
ChrisH
Return to Blender
Who is online
Thu Aug 13, 2020 12:51 am [ UTC ]
