Page 2 of 2
Re: Constantly getting this error using latest script on 2.6
Posted:
Mon Sep 10, 2012 6:49 pm
by steveps3
Just to check, you are using version 1.19 of the exporter?
Posted:
Tue Sep 11, 2012 3:00 am
by DayVids
The same error happens with both 1.19 and 1.20
Posted:
Fri Sep 14, 2012 6:50 am
by yoyoz
Just a quick note for those trying to help: I've instructed DayVids via PM to test the following:
in blender's python console, type following:
import os
os.path.isdir("N:\dddd\ddd)
where N:\dddd\ddd is the path he puts in "Image Output". If the last command returns false it means there's an issue with the path according to python (mostly non-existing). If it returns true then my space detection utility is broken and I've to fix it....
If you have same problem, please try this first.
Yoyoz
Posted:
Fri Sep 14, 2012 8:26 am
by DayVids
The issue is that when I put in a file name for the image output, Blender looks for a folder with that file name. So if I create a file name called "ddd" in folder "D:\dddd", it creates a path labeled "D:\dddd\ddd" where that last "ddd" is expected by python to be the last destination folder.
The resolution to this is to make a folder name the same as your desired file naming, and you will then have successful exports and opening of Octane.
I thought I was going crazy, now finally it makes sense, I just didn't understand how Python looked at path names.
Posted:
Fri Sep 14, 2012 8:52 am
by yoyoz
In fact the exporter only expects path names, as the file names for the pictures will be based on the project name
