When attempting to render an animation with 26 characters, I get this on the console and the render stops after one single frame. On other tests, I sometimes rendered two frames before the render stopped with same message.
I rendered successfully 7 frames with only 4 characters exported. As they are almost all similar in structure, what could cause the trouble ? I checked and only mesh objects and the exported camera (named Camera) are present and selected in the scene in Blender (no empties). The characters are all selected and the 3 Context boxes are enabled : Selection Only, Remove Hidden, Remove Invisible.
Characters are boneless and animated by Shapekeys.
At a moment, it seemed that both selecting the camera and checking the export camera box caused the trouble, so I tried again with the camera unselected and the Camera export box enabled... without success.
As I can get the animation work with some characters, I think that some others have a problem, but as they are very similar in the principle, I can't find what is going wrong. Any clue ?
With 26 characters, it is very hard to find the culprits. I tried to export them by adding one character at each export, but when troubles happen, I don't see any difference with other characters that work.
