Postby haffy » Wed Sep 15, 2021 7:13 pm
haffy Wed Sep 15, 2021 7:13 pm
Is there a demo version for Cinema 4D Metal ? I want to compare it for real (inside Cinema) to other renderers I look at.
And what options do I have to work on a MacBook Pro, an eGPU like Razer Core X or what?
3D Generalist.
haffy
Postby bepeg4d » Thu Sep 16, 2021 6:20 am
bepeg4d Thu Sep 16, 2021 6:20 am
you can find C4D OctaneX PR11 Big Sur Free Prime plugin at OTOY shop page here:
https://render.otoy.com/shop/primex.php
Here is the direct link
https://render.otoy.com/plugindownloads ... e-PR11.zip
It is limited to max 1x GPU, and it requires Big Sur 11.2 or greater, with an AMD GPU or Intel SkyLake GPU (not mixed with AMD GPU) (Apple M1 GPU support is considered beta/experimental)
The Prime tier is free for at least all of 2021. The expiration date that you see is a rolling expiration date, so it will continue to automatically extend itself as needed.
About eGPU, you can add one of the supported AMD GPUs in an eGPU box connected via Thunderbolt 3, here is a graph of speed in Standalone OctaneX under 11.4:
OctaneX scales linearly, so if you add a second GPU of the same type, the rendering speed will be 2x and so on.
Happy Mac GPU rendering,
ciao Beppe
Postby mitchino » Fri Sep 17, 2021 9:58 am
mitchino Fri Sep 17, 2021 9:58 am
When you say the free Octane X is limited to 1 GPU, can it be used with Apple's duo mpx modules - e.g 6800x duo?
mitchino
Postby bepeg4d » Sat Sep 18, 2021 6:31 am
bepeg4d Sat Sep 18, 2021 6:31 am
mitchino wrote:When you say the free Octane X is limited to 1 GPU, can it be used with Apple's duo mpx modules - e.g 6800x duo?
Yes, but only at 50% of its power, since only one of the two GPUs can be enabled at time.
You should need at least a Studio license to use it at 100% (max 2x GPUs), or, since mpx modules can be used only with new Mac Pro, you can use the Enterprise Mac Pro edition, free for now, that doesn't have any limitation:
https://home.otoy.com/render/octane-render/mac-pro/
ciao Beppe
Postby joschmidthaler89 » Mon Sep 20, 2021 3:39 pm
joschmidthaler89 Mon Sep 20, 2021 3:39 pm
joschmidthaler89 wrote:
bepeg4d wrote:Hi Jo,
please have a look at this solution here:
viewtopic.php?f=139&t=76283&p=395753&hilit=rndr+command#p395753
ciao Beppe
Hey Beppe. Thanks for the quick answer.
This is exactly the problem I am facing and the suggested workaround just did the trick. YES! Finally.
Works perfectly now with the last bigger scene I tested. :D
Maybe this information helps with finding the problem:
I just re-rendered 2 scenes I exported and uploaded to RNDR back in October 2020 with PR6 on Catalina for testing.
Both animated scenes (each more than 250 frames) had no issues at all. So it seems the "glitch" in the ORBX-Export
must have come later on into the C4D-Plugins?
lg
Jo
Hey. The Solutions that worked last time ist not doing the job anymore?
I'm getting an "FumeFx library initialisation error!" when trying to export an orbx as suggested – no matter what file.
The strange thing: I don't use FumeFX
Can you help me?
Log-File:
Drawport API initialized
Framework : Metal
Vendor : AMD
Device : AMD Radeon RX 6900 XT
Framework version: 2.2
Driver version : 2.2
Loaded Octane DLL:Octane X Enterprise PR11 version:10000306 SDK:PR11
Octane X for Cinema 4D PR11 built for:230 C4D vers:24111
C4D:24111 comp:[Jos Mac Pro] OS:[OS X 64 BIT] macOS: Version 11.5.1 (Build 20G80) versType:10
CPU:[GenuineIntel, stepping 7, model 5, instruction family 6] speed:3.2 GHz numOfCpu:32Ht
Plugins:[addons advanced_render alembic archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_viewport_render c4doctane-R24 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing corona4dR23 cyctypes deltamush deployment dropzone dwg dwgobjects dynamics exchanges expressiontag farm23 fbx gltf gorillacam goz greyscalegorillahub hair hdrilink i_skp interop io_obj lightkit3 lighttypes metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater physx_hybrid pluslibrary projectassetinspector python relaxuv RKT Slicer R23 scenemanager sculpt sculptbrushes shader signal sketch sky sla spacemouse substance teamrender thinking_particles tool_system_hybrid topcoat tpoperators usd uvviewport volumes xpressocore xtensions ]
Loaded 90 osl scripts from dir:/Users/joschmidthaler/Library/Preferences/Maxon/Maxon Cinema 4D R24_36E19156/plugins/c4doctane/res/osl_scripts
RKT Slicer V(1), 24111, OS X, /Applications/Maxon Cinema 4D R24/plugins/RKT Slicer Mac
Corona Renderer for Cinema 4D, version 6 hotfix 1
Version of core 6
(c) Chaos Czech a.s., 2014-2020
Plugin successfully loaded
HDRI Studio Rig V(2.152) - for R23+
Traceback (most recent call last):
File "GePython", line 7, in <module>
AttributeError: module 'urllib' has no attribute 'urlretrieve'
Export orbx:/Users/joschmidthaler/Desktop/Export.orbx start:-1 end:-1 step:0
VRAM used/free/max:0Kb/15.984Gb/15.984Gb Out-of-core used:0Kb RAM used:56.748Gb total:256Gb OpenGL free/total:0/0
1-Start Orbx Export....
<< exportAnimatedORBX >>
ResetAndInit 1
ResetAndInit [OK]
Multi-threaded material conversion, thread count=30
joschmidthaler89
Postby tolitoli » Tue Sep 21, 2021 1:01 am
tolitoli Tue Sep 21, 2021 1:01 am
I can't open the Vectron presets, every time crashes
tolitoli
Postby iRota » Fri Sep 24, 2021 10:47 am
iRota Fri Sep 24, 2021 10:47 am
Hi, no matter how many times I check "low" priority it goes back to "high" or to unchecked "use priority".
According to Otoy´s recommendations when using one gpu : "low" and "use priority" should be checked.
Why does the plug-in reset it everytime?
I understand the wrong set-up causes instability and crashes, and when Cinema is opened back again the previous set-up might -sometimes- have been changed.
It will end up crashing again if one forgets to check it everytime C4D is started, and so back to the start until one remembers this set-up might have been absurdly changed.
Is there a solution for this?
iRota
Postby bepeg4d » Mon Sep 27, 2021 7:50 am
bepeg4d Mon Sep 27, 2021 7:50 am
@ joschmidthaler89:
the Fume error is not important, please check the path of the c4d scene, if on network path, try to move it in your local hd.
@ tolitoli:
everything is working as expected here with Vectron:
If you have a Mac with an Intel GPU + AMD, you need to completely disable the intel GPU, and render only with AMD.
@ iRota:
please, try to delete the oct.dat file, at the following path:
`/Users/UserName/Library/Preferences/Maxon/Maxon Cinema 4D R2X_XXXXXXX/prefs/oct.dat`
ciao Beppe
Postby iRota » Mon Sep 27, 2021 4:12 pm
iRota Mon Sep 27, 2021 4:12 pm
Hi Beppe, tried your tip -several times- but it does not work, priority goes back to high as soon as C4D is closed.
Thanks anyway.
iRota
Postby bepeg4d » Tue Sep 28, 2021 7:06 am
bepeg4d Tue Sep 28, 2021 7:06 am
iRota wrote:Hi Beppe, tried your tip -several times- but it does not work, priority goes back to high as soon as C4D is closed.
Thanks anyway.
Weird, please write to help at otoy dot com asking for me.
ciao Beppe
PreviousNext
Return to SketchUp
Users browsing this forum: No registered users and 26 guests
Wed Apr 24, 2024 11:48 pm [ UTC ]
