Octane Render for SketchUp 3.08.1.0 Stable Release
Forums: Octane Render for SketchUp 3.08.1.0 Stable Release
Re: Octane Render for SketchUp 3.08.1.0 Stable Release
Postby manos » Thu Jul 19, 2018 8:14 pm
manos Thu Jul 19, 2018 8:14 pm
Hello....i use the plugin as an exporter to the standalone ....but the material picker is not working ....any way to fix this ?
CPU: INTEL i7 3.40 GHz/RAM: 8 GB/GPU: 2XGTX690/OS: WIN 7 64 BIT/SKETCHUP 2014/OCTANE for SU
manos
Postby azen » Thu Jul 19, 2018 10:10 pm
azen Thu Jul 19, 2018 10:10 pm
manos wrote:Hello....i use the plugin as an exporter to the standalone ....but the material picker is not working ....any way to fix this ?
Hi Manos,
Just to clarify - are the Materials in the Sketchup Material Picker not applying to your geometry? Are the materials applied from the Sketchup Material Picker not showing up correctly inside the Octane Viewport? Any specific details about how the Material Picker is not functioning correctly would be greatly appreciated, as this will allow us to replicate the issue on our end.
Also, please confirm the SU version, OS, and CUDA Driver version numbers on your machine.
Cheers,
Azen
azen
Postby manos » Fri Jul 20, 2018 1:55 pm
manos Fri Jul 20, 2018 1:55 pm
The su I use is 2017 but I think I had the same problem with 2018 also....It seems that when exporting from su the picker doesn’t respond like nothing is picked....but when exporting a obj or from 3d max it works fine...It has to do something with the file that the plugin produces ....
manos
Previous
Return to SketchUp
Sun Jun 16, 2019 10:44 pm [ UTC ]
