Octane Render for SketchUp 3.04.4.7 Test Release
Forums: Octane Render for SketchUp 3.04.4.7 Test Release
Re: Octane Render for SketchUp 3.04.4.7 Test Release
Postby haze » Sun Dec 04, 2016 7:39 pm
haze Sun Dec 04, 2016 7:39 pm
They should still work as smicha said, I'll find out and we'll get this fixed.
haze
Postby Jorgensen » Sun Dec 04, 2016 7:40 pm
Jorgensen Sun Dec 04, 2016 7:40 pm
Im not sure if i do something wrong
Jorgensen
Postby Jorgensen » Sun Dec 04, 2016 8:37 pm
Jorgensen Sun Dec 04, 2016 8:37 pm
it seems that the proxy worked with a other model - not sure why.
Jorgensen
Postby resmas » Mon Dec 05, 2016 11:33 am
resmas Mon Dec 05, 2016 11:33 am
Hello all, hope i find you very well and happy.
I have been away for some time now, and i still open the forum just to see if anything major as happened. I ask for your help to save some time.
Is there anything new?
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
resmas
Postby smicha » Mon Dec 05, 2016 11:44 am
smicha Mon Dec 05, 2016 11:44 am
resmas wrote:Hello all, hope i find you very well and happy.
cheers
resmas
Hi resmas,
We are witnessing the new nodal approach, but long journey ahead :) I hope SU team will not slow down ;)
Win7, Modo 10.1, Octane for Modo and Sketchup, nVidia latest, TITAN+3x780 6GB, 2600K, P8P67WS, 32GB, 1350W
SMH10, EK, Airplex_480, SR1_560, 20xNB_PL2, 2xD5, Aquaero 6XT
smicha
Postby haze » Tue Dec 06, 2016 3:00 am
haze Tue Dec 06, 2016 3:00 am
resmas, glad to see you again.
For the current stable release, CC has fixed several issues since and brought out support for SU 2017.
We've made progress delivering phase 1 of the node graph upgrade. Phase 1 is editing octane materials in the node graph, and saving/loading this with the .skp. We're a bit concerned about the workflow, so we have released it as a test build. Phase 2 and 3 of the upgrade are for enabling editing geometry in the node graph, and also render settings etc.
Right now as I write this, CC is working on embedding generated images with the .skp file, so that your work will be portable.
We have also prioritised the overhaul of the UI, removing Flash components that have given us all huge headaches. We've done this so that we can create a much better workflow faster, and also eliminate the Flash event loop that has proven to be quite unreliable in the past.
haze
Postby -rb- » Tue Dec 06, 2016 12:13 pm
-rb- Tue Dec 06, 2016 12:13 pm
Again - thanks for all the dedicated work Haze!
- Rich
-rb-
Postby -rb- » Tue Dec 06, 2016 2:02 pm
-rb- Tue Dec 06, 2016 2:02 pm
Having said that...
Materials developed in node view aren't saved with the file (so defaulting when file saved and re-opened), material names not updating in the old UI - some materials (loaded from LiveDB) appearing in node view but not in old material picker UI :| ...And no 'undo's' - tell me we'll have undo's...
SU 16.0.19912 Win 10 Pro
- Rich
-rb-
Postby haze » Tue Dec 06, 2016 7:20 pm
haze Tue Dec 06, 2016 7:20 pm
-rb- wrote:Having said that...
- Rich
Materials created/edited using the node graph editor should be saved with the .skp, if it isn't, that's a bug. Confirmed material names not updating, will get CC to fix that.
The node graph editor is an Octane core feature, so we will need to investigate the undo system issue separately to the plugin. Thanks for the report!
haze
Postby ff7darkcloud » Mon Dec 12, 2016 6:49 pm
ff7darkcloud Mon Dec 12, 2016 6:49 pm
Hello, I keep getting this bug I mentioned before. Where the geometry keeps reloading after the viewport is closed.
It happens more often when I explode an object. Iam using the SketchUp 2017 plugin.
Thanks.
( PC ) Win10 x64 | 2xRTX2080TI | ASUS Rampage VI Extreme | i9-7900x | 32GB | 1600W
( Laptop ) Win10 x64 | RTX2080Max-Q | Lenovo Legion Y740 | i7-9750H | 32GB - Octane Standalone Win 10/ Sketchup 2019
PORTFOLIO: https://renderspace.wixsite.com/portfolio
ff7darkcloud
PreviousNext
Return to SketchUp
Who is online
Users browsing this forum: No registered users and 2 guests
Tue Jan 26, 2021 12:16 pm [ UTC ]
