Octane Render for SketchUp 3.03.2.2 Test Release
Posted: Tue Aug 09, 2016 11:02 pm
This update contains only changes to the SketchUp plugin; the Octane DLL is still the current Octane 3.03.2 release. The main change since the last plugin release is some internal changes to file name handling to avoid save errors.
The 2.x and 3.x plugins cannot be simultaneously installed with the same copy of SketchUp. Installing the 3.x plugin should replace the 2.x plugin if you already have it, although we recommend uninstalling any existing plugins first. If you install the 3.x plugin and want to go back to 2.x, you will need to fully uninstall the plugin before reinstalling 2.x.
Changes in the Octane 3 SketchUp plugin are mostly internal to the Octane rendering code; the SketchUp side of the application works pretty much the same as it did in the 2.x plugin. Changes to better integrate the new Octane features with the SketchUp user interface will be added in future releases, but this initial release is essentially the new Octane 3 rendering code integrated into the existing SketchUp plugin.
Major Changes (since 2.x)
* Like the Octane 3 standalone version, the SketchUp plugin uses the new single sign-on system. You still need to have purchased a license for the SketchUp plugin, but it will now be checked automatically when you log in using your Otoy account credentials; you no longer need to keep track of user IDs and passwords for individual licenses.
* Because most rendered images are now stored in your computer's main RAM instead of your video card's RAM (see the section on host film buffers in the Octane 3 feature list), all Octane 3 applications, including the SketchUp plugin, will frequently use a good deal more memory than their Octane 2 equivalents, especially for high resolution renders. You should keep this in mind when upgrading.
* The new authorization management window is a modal dialog where the user can sign out and sign in. It also informs the you under which name you are signed in and if that sign-in was in offline or online mode. When a user signs out, all of your licenses which were activated on this computer will be deactivated. This requires that all these licenses are currently not in use by other Octane processes. If that's not the case the sign out will fail.
* Because of ongoing changes to the license management system, you should avoid mixing different 3.x Octane installations on the same computer. Please make sure that all Octane standalone and plugin installations are the same version. (Expect this to be relaxed in future releases.)
* 3.03+ releases include experimental Pascal GPU support. Please note that we are still working on performance issues there.
SketchUp Version
- The plugin requires SketchUp 2015 or 2016 for Windows x64.
- SketchUp 2016 is recommended.
- If you are using SketchUp 2015, remember to select this when installing the plugin.
- If you have multiple versions of SketchUp, plugins are installed separately for each version.
- The plugin is not compatible with any x86 (32-bit) version of SketchUp.
System Requirements
- 64-bit Intel or AMD CPU.
- Microsoft Windows 7, 8, 8.1, or 10 for x64.
- Windows 10 compatibility is still provisional; Windows 8 or 8.1 is recommended.
- One or more recent model Nvidia GPU cards.
- Nvidia drivers 353.x or later; CUDA 7.5 support is required.
More Information
- SketchUp plugin manual (2.x)
- New features in Octane 3.0 (manual)
- New features in Octane 3.0 (forum)
- Octane 3.0 release notes
- Octane 3.03.2 release notes
- Post your questions here on this forum thread!
Support Information
- Operating system (e.g. Windows 8.1 x64)
- Amount of RAM
- Graphics cards - model (e.g. Nvidia GTX 690 with 4GB)
- Nvidia driver version (e.g. 365.10)
- SketchUp version (e.g. SketchUp Pro 2016 version 16.1.1449 64-bit)
- OctaneRender for SketchUp version (e.g. 3.03.2.2)
Download Links
- Current 3.x beta release
- Current 3.x demo release
- Current 2.x release
- Current 2.x demo release
Release Notes
3.03.2.2
- Tweaks to internal file name manipulation code to avoid save errors due to invalid paths.
3.03.2.1
- Rewritten shutdown process to address license deactivation issues.
3.03.2.0
- Compiled with Octane 3.03.2b SDK.
- Changes to file path handling code to address issue with user home directories on network paths.
3.02.0.0
- Compiled with Octane 3.02.0 SDK.
3.01.1.0
- Compiled with Octane 3.01.1 SDK.
3.0.1.21
- Compiled with Octane 3.01 release SDK.
- Added authorization management window
3.0.0.20:
- Compiled with Octane 3.0 release SDK.
3.0.0.4:
- Compiled with Octane 3.0.0 beta 4.
- Added a demo version.
3.0.0.1:
- Compiled with Octane 3.0.0 beta 1.
- Internal changes to texture rendering, LiveDB access, and licensing for compatibility with Octane 3 API changes.
SketchUp Version
System Requirements
More Information
Support Information
- Amount of RAM
Download Links
Release Notes
3.03.2.2
3.03.2.1
3.03.2.0
3.02.0.0
3.01.1.0
3.0.1.21
3.0.0.20:
3.0.0.4:
3.0.0.1:
