Instancing / Forest Pro
Forums: Instancing / Forest Pro
Re: Instancing / Forest Pro
Postby Jorgensen » Mon Jun 16, 2014 6:58 pm
Jorgensen Mon Jun 16, 2014 6:58 pm
Hi
I have purchased the HQ plants pack 1 from www.3dmentor.ru.
Does anyone know if it's possible to convert them to obj or any other format to use them in sketchup?
I have tried to export from 3ds max as obj. It seems that the geometri gets exported, but the materials won't.
Ps. also asked this on the generel forum.
Jorgensen
Postby fuzzybro » Mon Jun 16, 2014 8:31 pm
fuzzybro Mon Jun 16, 2014 8:31 pm
Jorgensen wrote:Hi
I have purchased the HQ plants pack 1 from http://www.3dmentor.ru.
There are no materials at all or they being converted to a simple materials?
It might be that materials are configured to be used with V-Ray and thet are not supported by 3ds max exporter.
fuzzybro
Postby Jorgensen » Tue Jun 17, 2014 12:29 pm
Jorgensen Tue Jun 17, 2014 12:29 pm
No there is no materials exported.
It seems to be vray materials. So this might cause the problem :-/
Jorgensen
Postby resmas » Tue Jun 17, 2014 1:29 pm
resmas Tue Jun 17, 2014 1:29 pm
Jorgensen wrote:No there is no materials exported.
hello mate, its easy.
Just open the .Obj in StandAlone, tweak the materials (with Octane materials, because even if obj stored the vray materials, they dont work in Octane) after you setup your tree with the original textures applied in Octane save that tree with Octante_StandAlone as your personal object library . As a .OCS file and then load in Sktechup as Proxie and all is perfect. :D
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
resmas
Postby resmas » Tue Jun 17, 2014 2:00 pm
resmas Tue Jun 17, 2014 2:00 pm
Jorgensen wrote:Hi Pascal
You're right I did scale inside the component. So now it works.
But how does one scale a forest with 100+ trees?
I don't know if it's possible, but could this be possible?
- scaling the component on outside, scale only the 'attached' proxy
- scaling inside the component scales all proxies.
Thank :-)
Hello mate, if you need to scale all the trees that are already scattered in your model and you just need to make them all a bit more tall, short, fat, ect. Open the .obj file in your modeling software then scale/change to your needs, save and update in SU. All scattered "trees" will load the new .obj info and will update to the changes you made. ;)
cheers
resmas
resmas
Postby Jorgensen » Tue Jun 17, 2014 2:07 pm
Jorgensen Tue Jun 17, 2014 2:07 pm
Hi remas
thanks for your effort.
i have tried to import the obj into the standalone version. but it seems that it comes in as one single mesh :-/
Jorgensen
Postby resmas » Tue Jun 17, 2014 2:27 pm
resmas Tue Jun 17, 2014 2:27 pm
Jorgensen wrote:Hi remas
Hello mate, can you explain what you need to do? So we can see what can be done...if we know :?
cheers
resmas
resmas
Postby Seekerfinder » Mon Jun 30, 2014 4:19 am
Seekerfinder Mon Jun 30, 2014 4:19 am
Phantom107 wrote:I use SketchUp too for my modeling. I know exacly what SketchUp is missing and because of that I'm working on a bunch of new tools and features that will create a lot more possibilities.
Can't wait to see what you have in stall for us, Guus!
Seeker
Seekerfinder
Previous
Return to SketchUp
Who is online
Users browsing this forum: No registered users and 9 guests
Fri Apr 19, 2024 3:06 pm [ UTC ]
