Re: Octane Sketchup Exporter 1_00-04 [v2014]
Posted: Sun Mar 09, 2014 12:19 pm
Assuming you have v8 [latest update, >=M2 ] or any newer SketchUp - v2013 or v2014, then open Preferences > Extensions > Install... button - click, then find the RBZ and it is processed for you into your default Plugins folder...skibbbi wrote:How to install rbz? There is a lot of help
https://www.google.pl/search?q=how+to+i ... 2&ie=UTF-8
You need to add .RBZ onto the very end of the ZIP file so it is recognized...
fileName.zip --> fileNme.zip.rbz ]OR fileName.rbz] will do it...
Alternatively get the SketchUcation PluginStore Toolset.
That has a submenu item to 'Install Archive' - which processes RBZ or ZIP archives and installs the contents for you into your default Plugins folder... or if you have optional others they are offered too [unlike the native Installer...]
If you have an unsupported SketchUp version < v8M2 then you do not have an RBZ install capability - therefore you must do the manually extraction and installation from the ZIP archive as described in the documentation...
