help me i am the new guy
Forums: help me i am the new guy
Postby khaled » Sat Oct 02, 2010 10:14 pm
khaled Sat Oct 02, 2010 10:14 pm
i have some quistions in octane first i want to make ies light or make emitter material
seconde i didn`t know how to make a normal map in octane render
third when i render animation octane export obj in every fram and this take a lot of time there is any way to export the obj one time in the start?
sorry for my english and thanx
khaled
Re: help me i am the new guy
Postby bmneu » Sun Oct 03, 2010 4:36 pm
bmneu Sun Oct 03, 2010 4:36 pm
Im assuming from Sketchup? In sketchup, what I did was created a component for my lights. Its a cilinder with a smaller circle offset and pushed towards the ceiling just a little bit to depress it. The smaller circle, I made the material some crazy color like magenta so that I could notice it right away in octane. I exported, went to the material (by clicking on it in the overall view that you can get to by just clicking on your obj in the graph editor. Keep the material a defuse and at the bottom of the options is one called emission. Its currently at null, but change it to blackbody. THen you can play with the power options (i don't really see differences with the other two options). Hope this helps.
Core i7 X980 3.33GHz
12 GB RAM
GeForce GTX 480
bmneu
Postby TIG » Sun Oct 03, 2010 9:26 pm
TIG Sun Oct 03, 2010 9:26 pm
The light idea is the current best practice.
You can use scenes and animation export to control individual obj files for each frame - In the dialog answer 'No' when asked if you want to use the first scene's settings for each animation frame - then it takes longer as many more temporary files get made - but it will then pick up changes between the frames.
TIG
TIG
Postby khaled » Thu Oct 07, 2010 10:05 am
khaled Thu Oct 07, 2010 10:05 am
thank you very much and i will try this
khaled
Return to SketchUp
Who is online
Users browsing this forum: No registered users and 3 guests
Sat Sep 19, 2020 7:02 pm [ UTC ]
