Motion Blur Issues
Forums: Motion Blur Issues
Moderator: aoktar
Motion Blur Issues
Postby blastframe » Thu Jun 17, 2021 8:47 pm
blastframe Thu Jun 17, 2021 8:47 pm
Hello,
I have come across an issue with a camera tracking along with a moving object.
Here's the render of a scene demonstrating the issue:
https://youtu.be/5JHYcXRCDX4
Even though the rate of the cube and the camera are the same, the motion blur of the lights is extending. These lights should be static since they are static within the camera, as in this shot:
Here is my demo scene file:
https://drive.google.com/file/d/1uorYTZ ... sp=sharing
If anyone out there could help it would be very greatly appreciated. Thank you!
** EDIT **
I found this topic on the OTOY forums which suggests use geometry+an emission material, which I tried here:
https://drive.google.com/file/d/1nEea3m ... sp=sharing
The issue persists in the Live Viewer, but seems to be working in the Picture Viewer.
blastframe
Re: Motion Blur Issues
Postby jayroth2020 » Thu Jun 17, 2021 9:29 pm
jayroth2020 Thu Jun 17, 2021 9:29 pm
Thank you for the file. The issue occurs with Octanelights. If you create a mesh light instead, it will work as you expect.
See the rendering with the fix here:
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 1 EVGA RTX 3090Ti FTW3 Hybrid / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
jayroth2020
Postby blastframe » Thu Jun 17, 2021 11:00 pm
blastframe Thu Jun 17, 2021 11:00 pm
Thank you, @jayroth2020!
blastframe
Postby aoktar » Fri Jun 18, 2021 9:39 am
aoktar Fri Jun 18, 2021 9:39 am
Motion blur data is not accurate for every case in LV. Picture viewer mode can provide the better data, so PV is your reference. This is a limitation.
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 20 guests
Fri Apr 19, 2024 11:45 pm [ UTC ]
