print varnish
Posted: Tue Sep 10, 2019 4:14 pm
by mitchino
I have a label I'm rendering that has a white paper base, then some black type and grey type, some copper foil type, and then a logo that is a clear varnish on top.
I have created a composite material with image masks and glossy and metallic sub materials to define the different inks and foil, all works fine, but I can't seem to get the varnish to look right. Even if I use a specular sub material it renders opaque.
What would be the best approach?
Re: print varnish
Posted: Tue Sep 10, 2019 5:29 pm
by frankmci
You're talking about a fairly complex shader. It's very difficult to give any meaningful reply without an example of the problem, preferably a simplified scene file, or at least a screenshot of your shader tree and the resulting render.
