weird line under object
Forums: weird line under object
Moderator: aoktar
Postby mitchino » Tue Jun 11, 2019 2:40 pm
mitchino Tue Jun 11, 2019 2:40 pm
I'm doing a drinks render and I have a carton & bottle sitting on a reflective black floor plane. Behind the carton and bottle there is another wall plane, lit by an octane light with a spotlight gobo in the distribution slot.
For some reason the bottom of the carton is picking up the light along it's bottom edge. The only way I can get rid of it is too intersect the carton with the floor plane.
I can fix this in post but just wondering what's causing it?
mitchino
Re: weird line under object
Postby frankmci » Tue Jun 11, 2019 4:17 pm
frankmci Tue Jun 11, 2019 4:17 pm
Do you have some kind of refractive layer on top of your carton shader?
My go-to process for this kind of problem is to simplify the scene as much as possible while keeping the odd behavior. You should be able to quickly narrow down the range of potential culprits by swapping out the primary elements with more generic ones, one at a time.
And of course, posting an example scene that demonstrates the behavior will probably get you an answer quickly.
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby mitchino » Wed Jun 12, 2019 8:45 am
mitchino Wed Jun 12, 2019 8:45 am
I've discovered it's caused by Octane's usual problems with displacement. The carton material has some text on it that has a small displacement.
mitchino
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 25 guests
Sat Apr 20, 2024 2:32 am [ UTC ]
