Windowbox OSL shader?
Posted:
Tue Jan 15, 2019 5:46 pm
by jayroth
I have searched the forums, but I have not been able to locate the windowbox OSL shader for Octane and Cinema. Link, anyone?
Re: Windowbox OSL shader?
Posted:
Tue Jan 15, 2019 7:45 pm
by frankmci
You might be thinking of this link. I'm not sure the source data was ever posted directly on the OTOY forum. It's been a few months since I played with it, but I think it was the Lightwave OSL script that worked fine in C4D. Somewhere I've got a city block test file I built with it. It's pretty sweet!
http://julius-ihle.de/?p=2451
Posted:
Tue Jan 15, 2019 8:01 pm
by aoktar
Check presets from osl texture.
Posted:
Tue Jan 15, 2019 9:22 pm
by jayroth
I did. I saw nothing there what used the term "Windowbox" and none of the other names indicated that shader. I am happy to hear that it is included. Which one is it?
Posted:
Tue Jan 15, 2019 9:34 pm
by frankmci
It's not a full shader, it's example OSL code. You'll need to plug that OSL code into an OSL node in an Octane shader network. As I recall, it was the Lightwave version that I could just drop into C4D Octane. Also, the source .exr is defined by a path in the OSL node, not with an Image Texture node, at least in this implementation.
(edit) I went and re-downloaded the files to see what you are seeing. The jiWindowbox.zip file expands to a directory of .osl and .oso files. You want the jiWindowbox_LWOctane.osl file. Open it with your favorite text editor and copy/paste it into the OSL nodes Script Editor window. You'll also want the jiWindowBox_Examples.zip to have some .exr files to plug into the shader and as a template for building your own.
(edit 02) I decided to make a little quickie demo file for C4D users. This file uses one of Julius' (credited in the ReadMe) .exr files and the OSL code as written for Lightwave.
Posted:
Wed Jan 16, 2019 7:48 am
by jayroth
I was just about to start messing with this based upon your previous reply, and then I decided to review your post again, and I see your latest. It's fantastic! Thanks so much for doing this! Now I just need to some sources for input imagery!
Posted:
Wed Jan 16, 2019 7:36 pm
by frankmci
Sure thing, Jay. Thank you for EI back in the day; it was my workhorse back in the mid to late 90s!
Posted:
Wed Jan 16, 2019 8:00 pm
by jayroth
Thank you, Frank! I appreciate the sentiment!
Posted:
Sun Sep 15, 2019 5:56 pm
by 3dworks
i did try to load the example file into R20 + plugin V 4.0.5 R4 (latest) and check it. but when i double click onto the OSL node inside the material, C4D crashes. is this a known bug? any workarounds?
Posted:
Tue Sep 17, 2019 9:21 pm
by frankmci
3dworks wrote:i did try to load the example file into R20 + plugin V 4.0.5 R4 (latest) and check it. but when i double click onto the OSL node inside the material, C4D crashes. is this a known bug? any workarounds?
This doesn't directly answer your question, but as a data point, that example scene I posted in January still seems to work fine in Octane 4.03 and R20.059 on hardware similar to yours.
