Octane stops after 2 frames
Forums: Octane stops after 2 frames
Moderator: aoktar
Postby ChrisSuF » Wed Dec 12, 2018 4:53 pm
ChrisSuF Wed Dec 12, 2018 4:53 pm
Help! Octane won't render more than 2 frames. I rendered a whole animation just 10 minutes ago. Now, no matter what scene. even an empty one, Octane will stop after 2 frames. I rebooted my PC, deleted the C4D Plugin directory, reinstalled the Octane plugin. Nothing works.
ChrisSuF
Re: Octane stops after 2 frames
Postby niestudio » Wed Dec 12, 2018 5:13 pm
niestudio Wed Dec 12, 2018 5:13 pm
Currently being discussed here.
Perhaps you can provide the info Ahmet has asked for.
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
niestudio
Postby aoktar » Wed Dec 12, 2018 10:45 pm
aoktar Wed Dec 12, 2018 10:45 pm
Nothing helps you did! I'd help you if you share details of your scene. And how is octane log in Script/Console window?
Postby KeeWe » Fri Dec 14, 2018 1:18 pm
KeeWe Fri Dec 14, 2018 1:18 pm
I've the exact same problem right now. New scene works fine, but the scene I'm working in just stops after 2 frames. Where can I find the render Log? Under Help, Show Octane Log I just get:
Started logging on 14.12.18 14:05:04
OctaneRender 4.01.1 (4010100)
Ahmet, I send you the scene via PM if thats ok.
Edit: I found the problem: Since I was just doing some research I had one C4D Material with a Layer Shader in the scene. I deleted this material and everything works now.
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
KeeWe
Postby aoktar » Fri Dec 14, 2018 4:23 pm
aoktar Fri Dec 14, 2018 4:23 pm
Trying to use Layer shader is most common problem to break the Octane rendering.
Return to Maxon Cinema 4D
Users browsing this forum: Bing [Bot] and 25 guests
Thu Apr 25, 2024 11:13 am [ UTC ]
