Baking Texture node not working
Forums: Baking Texture node not working
Moderator: aoktar
Re: Baking Texture node not working
Postby Ferdinand13 » Sun Aug 19, 2018 1:53 pm
Ferdinand13 Sun Aug 19, 2018 1:53 pm
Hey Jay,
No worries and thanks for the suggestions.
After playing around with the node editor for another couple of hours, I think I finally nailed the problem and found the solution. In short, the Baked Texture node doesn't like image textures that are scaled down too much before they reach the node. Instead, it wants you to scale the texture within the Baked Texture node directly. Here's my thought process explained:
If you pipe an image texture directly into the Displacement node, all is fine and dandy, even if you scale it down quite a bit (0.1 on XYZ).
However, if you now throw a Baking Texture node into the mix, the result is suddenly a blobby mess and neither increasing the resolution on the Baking Texture node itself nor on the Displacement node can remedy that.
However, if you refrain from scaling the original Image Texture node (leave it at XYZ 1.0) and then scale it down directly on the Baking Texture node (to XYZ 0.1), you get more or less the same result, as if you'd have piped the Image Texture node into the Displacement node directly.
Hope this makes sense and that it saves someone else from pulling their hair out ;-)
Custom PC, Intel Core i7-6800K, 48GB RAM, 3x MSI GeForce RTX 2080 Super Seahawk EK, Windows 10
Razer Blade Pro 17, Intel Core i7-10875H, 32GB RAM, 1x NVIDIA GeForce RTX 3080, 1x EVGA GeForce GTX 1080 Ti Hybrid (eGPU), Windows 10
Ferdinand13
Postby jayroth » Sun Aug 19, 2018 5:53 pm
jayroth Sun Aug 19, 2018 5:53 pm
Glad you got it sorted, Ferdinand! Great info, too!
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
jayroth
Postby kasradesign » Thu Apr 01, 2021 5:27 pm
kasradesign Thu Apr 01, 2021 5:27 pm
Thank you. This workaround helped fix our problem too. It is not 100% same as without the baking node but close.
kasradesign
Previous
Return to Maxon Cinema 4D
Who is online
Users browsing this forum: No registered users and 21 guests
Tue Apr 16, 2024 1:12 pm [ UTC ]
