network error
Forums: network error
Moderator: aoktar
network error
Postby moose69 » Sat Apr 21, 2018 4:35 pm
moose69 Sat Apr 21, 2018 4:35 pm
Hi I am running C4D 3.08 with 2 licences of 3.07 stand alone.
when I set up network render I get an error stating invalid version 3.07.0 [307007]
both machines have had stand alone installed in the last couple of months and the version has not changed so I am lost as to why it has an issue.
Does running a release candidate ie 3.08 cause an issue?
any help would be good
moose69
Re: network error
Postby aoktar » Sat Apr 21, 2018 5:17 pm
aoktar Sat Apr 21, 2018 5:17 pm
Actually it says what's wrong: "invalid version ......."
You have to use exactly matching version on every machines
Re: network error
Postby moose69 » Sat Apr 21, 2018 5:39 pm
moose69 Sat Apr 21, 2018 5:39 pm
yes but the dates on the files on each install are exactly the same so they are the same install. I will reinstall the earlier one but I cant see it changing.
Will try
moose69
Re: network error
Postby moose69 » Sat Apr 21, 2018 5:51 pm
moose69 Sat Apr 21, 2018 5:51 pm
just installed 3.07 on both machine again. No Luck.
moose69
Re: network error
Postby aoktar » Sat Apr 21, 2018 6:20 pm
aoktar Sat Apr 21, 2018 6:20 pm
moose69 wrote:just installed 3.07 on both machine again. No Luck.
do you use same version for plugin too?
Return to Maxon Cinema 4D
Users browsing this forum: jayroth2020 and 38 guests
Thu Apr 25, 2024 4:44 am [ UTC ]
